Question about Alpine CHM-S620 6-Disc CD Changer
How do I find the model number on my Alpine cd changer in my 2002 Laguna as I need a magazine for it and have no manual.
    President:
  • Alpine Master
  • 1,114 Answers
There will be a silver or white tag on the back with the model and serial # on it. If it's not there, just visit a car audio shop that sells Alpine, any experienced installer with one look can tell you what it is. Hope this helps
Posted on Jun 24, 2009
My alpine CD player is showing a cd 3 error jam
Are all CDs in the magazine? If not, there may be one stuck in the changer
Sep 23, 2012 | Alpine Car Audio & Video
Dont know how to put disks in
You may download a copy of the manual here. The second page describes how to put discs into the magazine and the magazine into the unit.
Feb 17, 2012 | Alpine CHM-S620 6-Disc CD Changer
Cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Feb 09, 2010 | Alpine CHM-S630 6-Disc CD Changer
Looking for magazine for alpine chm 5620
The Alpine CHA- and CHM- changers all use the same magazine. You can search eBay or google shopping for "Alpine CHM Magazine" and you should see a variety of sellers, with prices from 25ish for used ones up to 40ish for new ones.
Feb 05, 2010 | Alpine Car Audio & Video
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
Apr 26, 2009 | Alpine CHAS-634 6-Disc CD Changer
''CDDJ ERROR'' WHEN ATTEMPTING TO PLAY VIA ALPINE CHANGER
My local Lincoln Dealership wanted to dismount the actual Clarion CD changer (I thought, and unfortunately reported to you, that the CD changer manufacturer was the same as the radio/cassettee unit that is installed in my dash, Alpine) from my 99 Town Car and ship the unit out for repair for a minimum of $130.00. Instead, I went to a local Radio Shack franchise who installs/repairs car electronic audio/video systems and they: dismounted the unit from the trunk; took the dismounted unit to their workbench; removed all the housing, etc. and finally were able to manually extract the fully populated 6 CD magazine stuck within the CD changer. Additional efforts (including inserting my spare magazine into the CD changer while it was on the tech's work bench) to determine exactly why the magazine would not eject while the unit was connected via the cabling to the car's power, etc. were not productive. So I now have a totally unassembled non-functioning CD changer on my hands. The "CDEJ Error" on the LED area in the dash when the eject buttoon on the CD changer is pushed.still persists. The technician said that it would be a waste of his time and my money to re-assemble the parts of the CD changer. He believes that the motor on the unit has been burned up.
So I am now checking with all the local auto parts salvage yards (we used to call them junk yards) to see if anyone has a usable Clarion CD changer for a 1999 Lincoln Town Car available that would be plug compatible with my existing Alpine factory installed Premium CD/Cassette audio system and the former factory installed trunk mounted Clarion CD changer. The Radio Shack franchise technician has already checked with the Clarion factory people and they iindicated that they no longer have my Town Car installed CD changer model available, new, used, refurbished or otherwise.
For what it's worth, here are the part numbers and other potentially important data that appear on the "cage"/sheet metal/housing that surrounds the working parts of the CD changer itself:
Assembly Part Number: F8VF-18C849-AE
Part Number (presumably the "cage"?): F8VF-18C830-AE
Date Code: 0998
Serial Number: 0201832
Mounting Orientation: Vertical
System Revision Level: 9.2
So it looks like I may have a potentially very expensive replacement of my whole audio system on my hands. I have been quite happy with my somewhat "obsolete" audio system and I have a very large collection of CDs which I migrate between my Sony 300 CD CDP-CX350 Mega Changer installed in my entertainment center, my car Cd changer and my Sony CD/Cassette player boom box in my master bedroom.
It was suggested to me that if I have to replace the radio/cd/cassette unit installed in the dash of my Town Car that I should consider a replacement model that offers a port to receive Ipod programming as a source of music.
So things have gotten somewhat complicated since the first instance of the Cd magazine not ejecting from the Clarion CD change mounted in the trunk of my car.
Maybe someone out there on your knowledge base knows where I can acquire a used Clarion model CD changer compatible with my car's setup at a reasonable price.
Thanks,
Tom
Nov 24, 2008 | Alpine CHM-S620 6-Disc CD Changer
2000 Lincoln Town Car Cartier CD Changer
My 2000 town car has a kenwood kcd-512c. but its only playing one track, which is what im looking for a solution to now :)
Aug 17, 2008 | Car Audio & Video
Manual removal of cd magazine
Seems to me an error of the installers, just go back and ask them to remove the magazine properly.
Aug 08, 2008 | Alpine CHA-1214 12-Disc CD Changer
Error 1 on alpine cha-s364
Quick Note: It's really helpful to your cause if you make sure you include more information about your system and what you're doing to get an error.
It's also a good idea to make sure you type in your model number correctly - you've typed in cha-s364 (the actual model you're talking about "I think" is a CHA-S634 - please verify!!
Here's a link to the user manual
As for the E-01 Error message on your CD Changer:
The E-01 reading is an error message, usually because the changer magazine is jammed in the changer. To manual eject out the magazine, take a thin plastic ruler (at least 5-1/2" in length) and slip it between the bottom of the magazine and the changer. Now, push in. This will hit a release button in the back. If the magazine does not eject, you will need to send the unit in to be serviced. To locate the nearest authorized service center to you call 1-800-ALPINE-1.
Note: if the magazine is half way out, but jammed, DO NOT try to release the magazine. You will need to send the unit in to be serviced by a technician.
May 29, 2008 | Alpine Car Audio & Video
Alpine CHM-S620 6-Disc CD Changer Logo
215 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
