Sometimes revs up to 1500to2000 revs without throttle pressed.
Throttle position sensor is faulty.
Is ur check engine light on? if so theres a problem related to a sensor, if not it should be the idle valve, placed on your throttle body
if ur engine is a x18xe the valve is possible to replace, if its a x18xe1 the valve comes with the throttle body and needs to be replaced as a whole , it might help to clean it up though...it must be checked
hope this helps
have fun
Take it to your local scrap heap as that's the best place for it!!
Engine keeps cutting out when slowing down and sometimes when starting up
smoke issuing from side of engine block
