Question about Ricoh Aficio SP C410DN Laser Printer
Printer will not print in color
Printer will print a color test page but not anything else in color ...is there a setting you can change?
  • 1 more comment
  • resnet Jun 25, 2009
    You shouldn't need to select color in preferences when printing from a word document,it should print in color unless you select black and white. there is no set default color for this printer and if there is I dont know where to find it. It is like the printer is set to print in monochrom, but i dont know where to go to change that setting on the printer
  • resnet Jun 26, 2009
    Thanks for your response but that didn't work. I ended up uninstalling the printer completely. Re-installing and getting new drivers..this worked..
  • Anonymous May 11, 2010
    ....So your selecting "color" in your "preferences" when you print a document, and it still prints in "black" ? What is the default color setting set to?
To select a specific document to print in color, open the document, Photo, etc, to print, select "print", then select "printing preferences" in the dialog box, select "color". This will print that specific document in color, but the setting will default back to B&W
Now, just FYI,
You absolutely need to set the default color, in your printing preferences - usually to Black and white -to save extra costs. The default setting is ALWAYS color when the driver is installed.. so even if you are printing a word document, the printer will "make" black out of the other colors, thus costing a lot of extra $$. Your settting has apparently been changed appropriately.
This is how it's set the default color should you ever want to change it, "right click" your printer icon in "Printers and faxes" select properties, select "printing preferences", and you will see, in the bottom left corner, the color selector, select "B&W", then select "apply", and close your dialog box. EVERYTHING will now print in B&W, unless you select otherwise, or vice versa if you swith it to color.
I hope that clears it up. Please rate my response
Posted on Jun 26, 2009
vyas
  • 36 Answers
SOURCE: color printing
Hi manatoba,
you have not told that problem was starts after replassing the ink cartridge or for this problem you replased
the cartidge.
First reinstall the printer driver, then reinstall the
cartridge if problem iteel presists takeprints from outher printer
check whether there is a problem or not with the printing if its happen again with the other printer also then ther is a problem with your opereting system,if not presist then problem is in priners card.
I hope after cheaking these things you can able
to solve the problem.
vyas
Posted on Apr 19, 2008
  • 5 Answers
SOURCE: My printer won't print in
Sometimes you have to go to Start -> Printers and Faxes, find your printer, right-click, and go to Properties. In one of the tabs, there may be a "Black & white" vs. "color" setting, usually in radio boxes.
Posted on Dec 09, 2008
preachw996
  • 1179 Answers
SOURCE: Printer not printing in color; new cartridge, tests are fine
Check your printer settings to make sure the print in b & w box is not selected. Hope this helps.
Posted on Feb 08, 2009
  • 630 Answers
SOURCE: red color cannot print
I presume the LCD screen on the printer also shows that there is toner. Take the toner out and reinsert it. If that doesn't work use the hp software to troubleshoot it may give more information.
Posted on Apr 04, 2010
  • 5524 Answers
SOURCE: printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Posted on Apr 15, 2010
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
Red color cannot print
Apr 04, 2010 | HP Color LaserJet 2600n Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Black prints roughly and no colors print at all.
download from epson website. the print head maybe dying.
Mar 25, 2009 | Epson Stylus 2200 InkJet Photo Printer
Feb 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
Printer won't print anything but a test page
Check printer settings. Also check windows setting for the printer. Also, be sure the printer is not offline.
Mar 05, 2017 | HP Office Equipment & Supplies
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Trouble with color printing
Have you tried to print a 'test page?'...
Go to 'Printers and Faxes'. Select right click on your printer and select 'properties' on the Printer properties window, select 'Print Test Page' (button at the bottom of the window.
Let me know what's the reseult.
Mar 11, 2007 | Canon MultiPASS C530 InkJet Printer
Ricoh Aficio  SP C410DN Laser Printer Logo
3,526 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
