Question about Cuisinart DCC-1200 Coffee Maker
Removing control panel
I would love to find out how to remove that control panel on the coffee maker to hush up that beep (five times!) when the coffee is ready. I am handy, but am chicken to go too far in removing it!
  • 7 Answers
!-- @page { size: 8.5in 11in; margin: 0.79in } P { margin-bottom: 0.08in } -->
To remove the faceplate:
You will need a tiny standard screwdriver (I used one from an eyeglass repair kit) and a smallish philips screwdriver. Begin by removing the carafe, the basket (and permanent filter, if you have one), the water filter, and the insert on the underside of the flip-up lid. With the lid open, you will notice two round screw covers towards the front of the coffeemaker to either side of the filter basket. Remove these with the small standard screwdriver. This is impossible to do without damaging them somewhat. Remove the two philips screws underneath .
There are nine clips that need to be released to remove the plastic top of your coffee maker. First, press in on and release the two located on the back just below the lid hinge. With the small standard screwdriver, gently release the six clips along the top edge of the casing. These are located two in back, near the corners and two along each side. You will have to get up underneath the plastic bezel, be gentle so that you do not bend the stainless steel housing (if you do, gently bend it back into place before you put everything back together). Lay the coffeemaker on its back. The final clip is located in the carafe “nook” to the back of the drip outlet. The upper plastic portion should now lift straight up out of the coffeemaker.
With the coffeemaker upright, remove the four philips screws holding the faceplate in place. Remove the faceplate by pulling it straight out towards you.
Posted on Nov 22, 2009
  • 85 Answers
Hello chasbrun,
I recently had this similar problem. I don't think you need to open the panel, try the following first:
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
Machine produces a bad burning smell when making coffee and the coffee also tastes very burnt. The machine is 5 years old
Sorry but if it were mine I think I would discard and buy a new one.Personally LOVE my bunn . not a fancy expresso maker but really good American coffee
Jun 17, 2015 | Sunbeam Cafe EM6910
When the cup button is pushed, the maker tries to make coffee (five or six grinding type sounds) but nothing happens. The screen reads "brewing" but no coffee comes out.
Run the keurig with vinegar instead of water. Then run it 5 times with only water just to remove the vinegar taste. Do this once a month. Also there are pins that pokes holes on top and bottom of coffee kcups, find the pins and clean it by unclogging with paperclips or some thinner wire. Buy a K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 09, 2013 | Keurig Elite B40 Coffee Maker
Removing hush panel on 2011 dodge journey
These 'found' answers from previous solutions are way off! I am looking at the (interior) fuses on a 2012 Journey.... the hush panel you mention is indeed tough to remove, but it is not necessary. The fuse box is to the right of it, in an opening cut into the hush panel. It is a SMALL unit! You can access two plastic locks on it. The bigger, easier one to reach is to remove the whole box from its holder. To just remove only the cover, press the little middle button on the smaller, left latch. Actually, tho inconvenient to reach, it is easy to take off the cover without tools. I hope this helps, and the this info form a 2012 applies to your car.
May 26, 2012 | 2011 Dodge Journey
Coffee maker will not brew,it is full of water and heats up but when the start switch is activated nothing happens even though it makes a slight noise like it is going to do something
This problem could be caused by a few different things. You need to make sure you unplug the machine before removing any panels. You should first check if you have the water turned onto the machine. Then you check if you have a bad inlet solenoid you can check this by simply adding a full coffee pot of water to the machine through the plastic lid on top. If it brews you know everything else is good and that you may have a bad inlet solenoid. There is also a timer on this machine that could be bad. Only way to test this is by removing the back panel of the machine and placing the red lead of a voltmeter on one side of the solenoid and one on the chassis of the brewer which acts as a ground. Hit the brew switch and see if you are getting voltage. If not the board may be bad. Last but not least the simplest, The brew switch maybe bad. Again make sure you unplug before removing panels. You can remove the top panel and unplug the two wires to the brew switch. Put the voltmeter in continuity mode and place the leads on each side of the switch. Hit the switch and see if you have continuity (which will cause the voltmeter to beep if there is). If not you have a bad switch. Hope this helps.
WWW.MidStateBeverage.com
Feb 09, 2011 | Brewmatic LA3 Coffee Maker
I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
Regards,
Harry B.
Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
My keurig shuts off about 8 times a day. Otherwise I love itL! Help! How can I get this to stop. I am thinking about returning it.
There is no fix other than removing water tank and slamming it back into place. There is a problem with with water draw thru the valves. If you search the web, you will see many people have same problem with the new B-70 units. Keurig will replace, but the design flaws are still there. Some people are on there 4 and 5th replacement. Keurig needs to step up and correct problem.
Nov 28, 2009 | Keurig B50 Coffee Maker
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
PRX20 Coffee Maker - Mr Coffe
I threw it away and bought a new one - this time a Bunn - LOL
Mar 20, 2008 | Mr. Coffee PRX20
Saeco vienna superautomatica
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Jan 23, 2008 | Saeco Vienna SuperAutomatica Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
583 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
