Question about LG LRTP1231W Top Freezer Refrigerator
Amana refrigerator not cooling below 45 degrees.
Amana refrigerator with top freezer. Turn up cooling and freezer all the way to 7 (the highest setting) and refrigerator only gets down to 45 degrees and freezer only around freezing (32). The condensor fan never comes on. Could this be the problem? All other components seem to be operating.
    Sergeant:
  • 212 Answers
The fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Posted on Jun 24, 2009
My freezer isn't cold enough. Are the higher numbers on the thermostat dial colder or are the low numbers colder? See full question below.
Hi, If I remember correctly, make sure the freezer control is set to on, otherwise neither will cool.
You need to give it 24hr for temp to settle, then check to see if freezer temperature is 0? to 2? F (-17? to -16? C).
Turn control to next highest number if too warm.
Turn control to next lowest number if too cold.
Allow 5 to 8 hours for adjustments to take effect.
Check to see that fresh food section is 38? to 40? F (3? to 4? C).
Hope this helps
David
Mar 02, 2018 | Amana Refrigerators
Maytag Refirgerator Model MTB2156FE freezer not cooling below 32 degrees
HI PAUL.FREEZER NOT COOLING could be for many reasons.go through the basics first .1-check if your freezer is iced up 2 if yes defrost it all completely first .then turn on 3-if ok then your problem could be 4-defrost timer 5-defrost heater 6-t/stat.if not iced up then check /clean thoroughly the condenser unit 7-check con/fan 8-check condenser should be warm/hot.if cold and motor hot then it could be lack of refrigerant (internal leak?) hope this helps.ALI
Jun 30, 2012 | Refrigerators
The freezer items are frozen,the refrig items are getting warm.i set it to the highest no.7 in the frig and its not getting colder
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
The refregerator will not cool below 45 degrees. the freezer is holding temp.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
I have amana DRS2662W- I had turned the defrost timer but now the freezer and the fridge are not cold enough- there is no ice forming, I can hear the compressor and fan behind but not cooling.
You should never need to advance your defrost timer. If your defrost is not working properly, the coil in the freezer compartment will ice up, blocking all airflow. All of your cooling is done there, even the refrig area, so you will never get down below appx. 40-45 degrees.
my first suggestion is to look at the back panel in your freezer for frost/ice build-up. If yes, unplug the unit, open the freezer compartment and let it thaw overnight. If it starts cooling properly, you have a defrost problem. It may be a bad timer(often), thermostat(less frequent), or bad defrost heater(even less).
Nov 15, 2010 | Amana DRS2663B Side by Side Refrigerator
Refrig does not cool to only 45 degrees Freezer is
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 08, 2010 | GE 18.2 Cu. Ft. Top-Mount Refrigerator -...
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
LG LRTP1231W Top Freezer Refrigerator Logo
341 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
