Question about RCA D52W19 52" Rear Projection Television
On my 52" rca high def big screen power light will flash three times then stop but won't power on. What is the cause?
    Problem Solver:
  • 3 Answers
I have the same problem and i open it a capacitor arround the flyback was burnt out
Posted on Jul 08, 2009
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
This stinking D52W20 is about to drive me nutz ....I was so sure I'd have her going I didn't even move from the living room ......she now rests in the shop ....I've checked every nook and kranny and no...
Youre going to need the deflection board as the high pitched whine if it sounds like a short chirp each time the power indicator lights for the 3 times is caused by a surge taking out numerous components on the deflection board. You can get your board rebuilt through www.tvrepairworld.com which is fully guaranteed for 6 months. New replacement boards are not available anylonger for the ITC222
Nov 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model 52" hd RCA tv Will not go on.hit power button green light keeps flashing.will not stop
These units are famous for bad capacitors in the power supply. When the capacitors go it causes voltages to fluctuate out of range. You have to remove the deflection PCB to repair this. Also look for loose connections at the high voltage transformer. This can be a dangerous circuit to work on. Have a repair shop check it out for you. Thanks
Oct 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power light flashes three times
Ur high voltage is dead,ur FBT,flyback transformer the big black block of plastic have a wire with a cap that hook up to ur CRT(tv tube).Might also ur DM power board have burns capacitors,it puff ups.U know how to solder?Tries this websites for repair parts.Tv Repair World.com Shopjimmy.com Partstore.com or Ebay.com.
Sep 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power light flashing three times. when came on screen was distort
very common problem you need to replace the flyback number 259296 and the CP150 you can get replacemnent flyback and cp150 at the following link with free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
205 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
