Question about Sony Handycam DCR-TRV140 Digital Camcorder
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
My camera displayed error message c:31:22 and a flashing eject sign with nothing working in either camera or vcr mode. I tapped it on side and bottom a couple of times and the vcr and camera functions were restored. However, the camera does not recognise that there is a tape in the camera. It shows o minutes of tape remaining and a tape icon slashed through it along woth an eject icon. I cannot film anything.
  • 72 Answers
Daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Posted on Jun 30, 2009
Why do I get the error code C:32:11 or C:31:42?
Does it try to eject the tape? Try a gentle help on that. The tape may have gotten snarled in the camera.
Sep 03, 2014 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
When i try to use my camcorder there's a flashing light with the eject symbol and it wont record or let me use the video
Flashing eject sign error appears when camcorder got problem in its mechanism, please put another tape and check.
Remove battery from camcorder for couple of minutes, put battery back and try.
Also observe does tape reels turns reverse and forward when tape loaded in mechanism.
If problem still exist, qualified camera tech will fix it because it is not user level repair.
Oct 13, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Nothing happens when I turn on the camera - message C:31:23
This error usually comes when there is some mechanical fault instead of the electronic one. Maybe the gears are jammed. Try it at your own risk:
I found this on another discussion forum. Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. Surprisingly it worked for me..
Apr 01, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Jan 22, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony DCR-TRV320
Try this (seems to be a standard thing from Sony):
  5. If an error message appears, service may be required. If the error ,message starts with an "E" it needs to be sent in.
Go to any large photo shop and get an estimate.
Aug 23, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony Handycam DCR-TRV140 Digital Camcorder Logo
834 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
