Question about Sony Playstation 3 (PS3) Console
Switch on and then the lights go on and off and
Switch on and then the lights go on and off yellow light appears and then switches its self off straight away
    Scholar:
  • 46 Answers
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps. Be sure to rate whether or not this was helpful.
Posted on Jun 26, 2009
What does yellow sun symbol on dashboard indicate?
Headlights failure.
If the yellow symbol appear as soon as you turn on the dashboard, stop's light bulbs may be the problem.
If the yellow symbol appear when you switch-on lights, the problem may comes from the position's light bulbs.
Ensure that all of the light bulbs are fully working.
Feb 16, 2016 | 2005 Fiat Punto 1.2
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
What is the color code for replacing the light switch on a '94 Marquis with factory alarm and keyless entry?
Here you go. I think this may be what you are looking for. I hope this helps and good luck.
1994 Mercury Grand Marquis Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Yellow Ignition Switch Harness Starter White/Pink Ignition Switch Harness Ignition Red/Light Green Ignition Switch Harness Accessory Gray/Yellow Ignition Switch Harness Tach Gray/Orange EDIS Module Brake Switch Light Green Brake Switch Trunk Release Purple/Yellow Driver's Kick Panel Trunk Pin Brown/White (-) Light in Trunk Parking Lights Brown Light Switch Head Lamp Red/Yellow Light Switch Hood Pin n/a Factory Disarm n/a Door Trigger Black/Light Blue Driver's Kick Panel Door Lock Pink/Yellow Behind Glove Compartment w/Keyless w/o Keyless (-) Door Unlock Pink/Light Green W/o Keyless Reverse Polarity Horn Wire Yellow/Light Green (-) Steering Column Windows Up LF=Yellow, RF=White/Yellow, Windows Down LF=White/BlackRF=Tan/Light Blue
Mar 26, 2011 | 1994 Mercury Grand Marquis
Dryer will not come on...interior light is on. push botton does not appear to work recommendation to trouble shoot..
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 19, 2011 | Kenmore 400 6942 Dryer
I have the WRT54G wireless-g router and I tried to switch it on (after I had switched it off because I was overseas). However instead of the yellow light to come on (over cisco systems logo), a white color...
Does the Cisco logo illuminate yellow? Is the power LED white?
In any case locate the reset button on the back. It is just to the left of the
Ethernet cable jack. With the power on, depress this button for 2-3 seconds and release.
All the lights should come on the go through a series of self tests. Once settled down after about
2 mins see if the lights change. If nothing changes, it sounds like it was dropped causing the
colored plastic tabs to jar loose.
Hope this helps.
Nov 29, 2010 | Linksys Wireless-G WRT54G Router
Ps3 doesnt turn on yellow light appears then it
This is the YLOD yellow light of death you need to fix this by stopping the heat internally use a good guide or send it in to be fixed.
Jul 04, 2010 | Sony Playstation 3 (PS3) Console
Warning Lights
Are your hazards lights on? I don't know your car but The triangle most of the time is hazards lights. Now when you turn your key on all the light should come on then go off, If on stays on in some cases it could be just a bulb. To check your Bulbs use you turn singles / blinkers. You can get them on by turning key to on with out starting car. Then turn on our left by pushing switch down first. Check driver side front & rear. Then check passenger side by switching to the right switch up. Good luck
May 17, 2010 | 1994 BMW 3 Series
It keeps turning its self off
This is an overheating problem.
Leave it off for a day and see if it works then.
Make sure it is atleast 4 inches away from everything, is not on carpet, and is not on anything that makes heat.
If it starts to do this as soon as you start te console up, and there is a yellow light mixed in there, then you have the Yellow Light of Death.
If it reaches that far, repost the question on here saying you have the YLoD.
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
Installing remote start
1996 Mercedes E-Class Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Red Ignition Switch Harness Starter Purple Ignition Switch Harness Ignition Pink/Black Ignition Switch Harness Ignition 2 Pink/Yellow Ignition Switch Harness, Accessory 2 Accessory Pink/Blue Ignition Switch Harness Tach Black Coil Brake Switch Black/Red Brake Switch Trunk Pin Brown/Yellow/ (-) Trunk Light Parking Lights Gray/White L And Gray R at Light Switch or Alarm Module Head Lamp White/Yellow (+) Light Switch Factory Disarm Blue (-) Driver's Kick Panel Door Trigger Gray/Black (+) Gray/Red Head Light Switch Door Lock Blue/Yellow (-) Driver's Kick Panel Door Unlock Blue/Black (-) Horn Wire Black/Yellow OEM Alarm in Trunk
Jul 18, 2009 | 1996 Mercedes-Benz E-Class
Playstation 3 (60gig) , I turn it on and the light turns yellow and turns it's self off
Hi there, what you are referring to is called the Yellow Light of Death (YLOD).This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. As it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3.
Hope this helps and thank you for using FixYa
Aug 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
76 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
