Question about Kenmore Dishwashers
Kenmore portable dishwasher won't drain model # 665 17799990
Just got a ten year old kenmore portable dishwasher, and they said all works great but doesn't drain at all model # 665 17799990 help
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Posted on Feb 08, 2012
SOURCE: Kenmore 665 Dishwasher Not Draining
After the first try of our dishwasher the water didn't completely drain. Ever since the same level of water hasn't drained from the dishwasher.
Posted on Jun 17, 2008
SOURCE: Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
Posted on Jul 18, 2008
reg501
  • 413 Answers
SOURCE: I have a kenmore 665 dishwasher where the spary arms do not spin.
  • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
  • If you can't hear the wash motor running or is just humming, the motor may be bad.
  • To check if the food chopper is blocked or broken;
  1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
  2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
  3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
  4. Remove the four torx screws from the sump cover, remove assembly.
  5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
  6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
Hope everything goes well for you,
Regards
Richard
Posted on Feb 03, 2009
  • 249 Answers
SOURCE: Kenmore 665 dishwasher washing light stays blinking
could be faulty outlet pump
Posted on Nov 28, 2007
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
Model 665.13929kq11. Why isn't it draining completely?
Dishwasher is draining slowly , and not completely ... - iFixit
https://www.ifixit.com/.../Dishwasher+is+draining+slowly+,+and+no...
iFixitJun 26, 2014 - I have a kenmore dishwasher (about three years old) ! ... with a solid plug in the drain tube for situations where a dishwasher isn't connected.
My Kenmore Dishwasher Won't Drain and is Leaking- How ...
? 5:35
https://www.youtube.com/watch?v=u7uaA2NZKl0
Nov 14, 2011 - Uploaded by mkbrennan13
This is a video to help someone fix their dishwasher. It's a How to fix your dishwasher that won't drain. If your dishwasher isn't draining and ...
How to fix drain problem with kenmore dish washer - YouTube
? 6:46
https://www.youtube.com/watch?v=ZMPXn6XgRkk
Aug 16, 2010 - Uploaded by itdatanow
Kenmore dishwasher would not drain. ... How to fix drainproblem with kenmore dish washer ... Is Your Dishwasher DrainInstalled Properly?
Dec 12, 2015 | Kenmore Dishwashers
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Periodic water leaking from Kenmore Elite K701
hello Adrian. I am suspicious that the standing drain pipe behind your machine may sometimes over flow. To find out, pack some dry newspaper around the drain hose where it enters the drain line behind the machine. If that newspaper gets wet you will know that the drain is sometimes overflowing. If that is the case, snake that drain or force a garden hose down it and run hot water thru it for ten minutes. J.
Jul 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My 1 year old Kenmore elite will not drain
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$&^
Apr 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a Kenmore Quietguard dishwasher, only a few years old, and it won't drain. I pulled it out and checked the drain hose, could not find a clog. I took the basket and sprayer out, couldn't find any...
I have a Kenmore Quietguard portable that won't stay connected to my kitchen sink faucet. Checked all I can and continues to spray the wall and me without staying attached securely to the faucet adapter. Help!! Any ideas?
Jun 17, 2009 | Kenmore 24 in. 15162 Built-in Dishwasher
Kenmore portable dishwasher not working
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Kenmore ULTRA WASH Portable Dishwasher Model 665.1784 leaks
i have had my dishwasher for 10 years never a single problem , i connected it turned it on , it filled with water then it just shut down down won;t do a thing. any ideas?
Sep 27, 2008 | Dishwashers
Soap door won't open
The rinse aid compartment on my Kenmore Portable dishwasher ( Model 17829) leaks and doesn't hold the solution. It seems to have done this for longer then I can remember. What can be the problem?
Sep 21, 2006 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
2,129 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
