Question about Amana ARS266ZBS Side by Side Refrigerator
Not cooling enough
I have used a vac to clean all areas of the coils and powered down refrigerator to make sure it was not iced. Still there is very little air flow coming through from the freezer to the refrigerator via the pass through. and the refrigerator does not seem to get any colder than the mid-high 40's Any ideas?
  • 21 Answers
Air baffle in refr stuck closed or bad control not letting open
Posted on Jun 25, 2009
The Refrigerator's Freezer is not working but the fridge is, what is wrong?
You probably have one compressor that cools the freezer section and the refrigerator section. Usually the freezer gets cooled directly with the cooling coils. A fan blows cool air to the refrigerator section. The air flow to the refrigerator may be modulated with some time of "air door". What you have written says to me, is that the fans and air doors are working but there is enough cold for the refrigerator but not enough for the freezer.
Here is what I would do:
  1. Put a thermometer in the refrigerator and in the freezer.
  2. Be sure the coils underneath or behind the refrigerator are clean. If they are very dirty, clean them.
  3. Keep the doors shut for at least 12 hours and then read the thermometers and write down the temperatures.
  4. Freezer temperature
    1. If the freezer has started freezing again, you fixed it by cleaning the coils
    2. .If the freezer temperature is between 0 deg F and 32 deg F, consider putting the food in a cooler and packing in some dry ice to try and save it.
    3. If the freezer is warmer than 32 deg f, throw away the food.
    4. Doctors and hospitals are pretty expensive. I would throw away the food no matter what the thermometer read.
  5. Look inside the freezer at the cooling coils. See if they are ice coated or not.
    1. If the freezer is above 0 deg F, and the coils are ice covered, the defrost control is not working. Unplug the refrigerator for 12 hours and let the ice melt. (Keep the doors shut.) Then, plug in the refrigerator for 12 hours and check the temperature like in step 3.
    2. If the freezer is above 0 deg F, and the coils are NOT ice covered, the compressor is not working.
  6. Call the service technician. When she comes out show her the temperatures and tell her what you found out about the ice on the coils.
Good luck
Jun 07, 2015 | Refrigerators
Side by Side Can't find model # Not cooling enough
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
GE Profile 21 cu ft. goes continuously except upon defrost, "once a day" for about 30 minutes. Unit cools both on freezer side and refrigerator side (ice cream ok and milk ok). Repairman...
open the doors and feel the middle strip.if that's hot check the condenser fan to make sure it's running and clean out the coil in the back.pull out the machine,remove the bottom panel,on the right side you'll see the coil,with a shop vac vac off the coil and then put it on blow and blow out the coil,that's the only way to clean this kind of coil and make sure the fan is blowing back there.let me know what you find,also send the full model number,open the fridge door,look at the right wall near the ceiling and you should see the model number.
Jan 23, 2011 | GE Profile Side-By-Side Refrigerator with...
Refrigerator doesn't stay cool enough
Sometimes it is just a matter of excess dirt and dust build up on your coils. Take the bottom toe- kick louver off your fridge and try to clean off your coils. Use a very small hosed wet-vac and a long neck feather duster to reach in and clean as best as you can. If this does not seem to help within a couple hours you may want to try a manual defrost. Reply back to this post and let me know.
Nov 30, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Not cooling low enough
Hello, A refrigerator or freezer that is not cooling, but cooling poorly, may have a problem in one of several areas:
EVAPORATOR COILS or
CONDENSER
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust,lint,and dirt.
EVAPORATOR COILS:Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build up, is the presence of any frost or ice build-up on the inside walls,floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gasket.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. if one of the components in the self-defrosting system fails, the refrigerator continues to try to cool.
system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to off, and leave the doors open for 24 to 48 hours (be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually". When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat(also called the bi-metal switch)
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor.You may need to consult with a qualified appliance repair technician to further diagnose the problem.
CONDENSER: Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt, or lint, the refrigetator may not cool properly. The coils may appear to be thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and a vacuum cleaner to clean the coils of any lint,pet hair, etc. You may not be able to get to all of the condenser from the front , it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Thanks
Jun 20, 2010 | Frigidaire FRT18FS6C Top Freezer...
My Kenmore side bt side isn't cooling. The
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 98d4754.jpgIf this was a slow moving loss you should clean the cooling coil under the refrigerator. Remove the bottom snap in grille and vacuum out the dirt and dust from the coil and anything else you can reach. You may need to make an extension with paper towel tubes flattened a little and tape to get into the cramped spaces. I use a piece of clear plastic pipe stuck in the suction with a long angled split cut on the cleaning end. Maybe also move the fridge out, vacuum and clean the flooring area also. (And every 6 months)
Apr 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Whirlpool freezeer making ice moist in addition of ice and the refrezerator does not cool enough. please any help.
if there is ice forming on the back wall of freezer then you have a defrost problem in the freezer,deheater,bimetal switch,defrost timer,all need to be checked-mike
Jan 24, 2010 | Freezers
How do I clean the coils? My refrigerator is freezing food off and on. I pulled the fridge out, but it's all covered in the back. How do I check the coils?
It breaths through the front on the bottom.If its like mine. The coils are down their.The cooling fan sucks air in one side and blows it out the other side on the bottom front. Take off the cover and use a vaccuum cleaner with a thin hose,lay down and carefully vac. as much as you can. If you have a dog or cat this area is going to be full of fur.It is hard to clean it well with out laying the unit down on its back. If you want to go that far have plenty of towels ready and a mop.(taking it out side is nice before laying it down)Of course the food comes out first and gos in a ice cooler. The MAIN rule is this, If you lay it down for 1 hour then let it stand for at least 1 hour before you plug it back in, 2 hours down at least 2 hours up before plugging it back in.This let the refrigerant oil go back where it came from.
Sep 01, 2009 | GALAXY Microsystems 25.4 cu. ft....
Freezer not cooling enough to make ice.
well countney778 it sounds like either your drain is clogged upo and holding water in the freezer or your defrost timer is bad. the timer shoiuld be by the thermostat area and the drain is at the boittom of the coil that is currently freezing. also look underneith and if you see abunch of dirt then you may have to clean the coil on the bottom of the unit. use a shop vac and a long brush to clean.
Jan 19, 2009 | GE Refrigerators
We bought a whirlpool gold fridge side by side a year ago. Lately, it has had some problems cooling both the fridge and freezer. We used to keep both of them on 4 or 5 setting, but now, even on 7 we're...
If fridge is not cooling enough see the reccomandation below from Repairclinic:
Evaporator coils
Condenser
  • The defrost timer
Sep 07, 2008 | Whirlpool Refrigerators
Amana ARS266ZBS Side by Side Refrigerator Logo
264 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
