PLEASE PROVIDE ONLINE INSTRUCTIONS TO PROGRAM SPEED DIAL NUMBERS ON A RICOH FAX MACHINE MODEL 2050 L. WE NO LONGER HAVE THE OWNERS/INSTRUCTION MANUAL. ANY HELP YOU COULD PROVIDE WOULD BE GREATLY APPRECIATED. THANKS.
Le Saucier is a kitchen appliance that is used to make fresh butter and other creamy sauces. Without knowing the specific model of Le Saucier you have, it is difficult for me to provide an instruction manual for the automatic dial. However, here are some general instructions on how to use the Le Saucier:
Assemble the Le Saucier according to the manufacturer's instructions. Typically, this involves attaching the paddle and placing the machine on a flat surface.
Pour the cream into the Le Saucier. The amount of cream needed will vary depending on the size of the machine and the recipe you are following.
Set the machine to the desired speed and let it run. The automatic dial may allow you to set a specific speed or program, depending on the model.
After a few minutes, the cream will thicken and eventually turn into butter. Once the butter has formed, stop the machine and drain off any excess liquid.
Use a butter churn or cheese cloth to remove any remaining liquid and shape the butter into a desired form.
If you are still having trouble with your Le Saucier or need a specific instruction manual, I recommend contacting the manufacturer or searching online for a downloadable manual.
Many of these devices have a Web Interface that you can access if you have administrator's rights (password) and the original password was not changed when the device was installed. If you are not using it as a network printer and only a fax, you would still need to login as the administrator to edit/delete/add fax numbers.
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Press the dataregistration key.dataregistration will apear on the screen press the arrow down untill Tellregistration will be displayed.Press set or ok or start.! Toutch speed dails will be displayed.Press set or ok or start.It will show the available one touvh numer.Enter and insert name and fax of the sender.
Go to the Ricoh site at the following link and under "facsimile", download the Fax 2000L manual, it's virtually identical. I don't know why they don't have the Fax 2050 version, as it is slightly more recent model, but anyway, this should work for you: http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
You can use the "Broadcast " feature to send one fax to up to 112 numbers listed in your speed dial. To set this up:
Insert the original into the ADF.
Press Quick Scan/Reports. The display should show how much memory is available.
Enter the One-Touch or Speed Dial numbers for the recipients you want to send to (one after the other). You can also setup a group dial number.
Press Fax Start. The machine will scan the document into memory and then dial all the numbers you've entered. If any are busy it will attempt to redial.
Press Stop/Exit at any time to cancel the broadcast.
If you need further instruction on how to setup group or speed dial numbers, Brother provides the user manual online.
Canon left me on hold for 30 minutes then told me this wasn't their problem and I should call my dealer for service. I'll try that now. Nope - they didn't know either.
Eureka! Lift the panel that covers the speed dial buttons and push the button labeled "data registration". Using the arrow buttons find the speed dial info and figure it out from there. Good luck!
