GE AGQ10AJ Thru-Wall/Window Air Conditioner
Problem for GE AGQ10AJ Thru-Wall/Window Air Conditioner
My window Arctic King isn't removing moisture. No
By lady_marilyn on Jun 24, 2009
My 2 yr. old window Arctic King isn't removing moisture. No manual. How do I know if it's open or closed? Also, I have it on "auto" and doesn't shut off. Should it be on "Cool" instead? 10,000 BTU for 600 sq ft house. Cools beautifully! Humid inside house. Thanks for any help!
Comments:
Jun 25, 2009
- I'm guessing a 10,000 BTU AC is big enough for a 600 sq ft house. It's been 75% humidity in the house for two days now, ever since I turned on the AC. It hasn't made a bit of difference. A question is, is the exchanger open with the pegs pushed in or pulled out? Maybe I have it wrong?
Jun 26, 2009
- Thanks for helping. I really appreciate it. I've looked for a manual and haven't found one, yet. The Model # is MWF1-10 CR. I have it set on these settings right now: Cool, Low EnergySaver and 73 degrees. Set like that at least it's not running constantly. But it's still not getting rid of any moisture. It may be in the open position and I wouldn't know it. In areas of high humidity, like here, I've been told you have to keep it closed or it will ice up. Does it not dehumidify on open a well?
Thanks, again,
Marilyn
Jun 29, 2009
- It is a window unit but I have it in the wall hole. I used metal tape to seal all around it as it doesn't fill the space.
I appreciate that you're looking for a manual for me. I would love to have one! I also have a Haier I use in my bedroom when this one can't keep up. Usually only a few weeks in July-August. No manual for that one, either. I bought both new but cheaper because they weren't in a box and no manuals. Now I wonder if it was worth it!
Damper, is it? I'll push them in and see if it makes a difference. I didn't want to do that in case it was the wrong thing to do. But at this point........!
Jun 30, 2009
- Thanks so much! It's a Haier HWR06XC3 Window Air Conditioner. Is that all you'll need? I don't undertand the buttons on that one at all! All this digital stuff. Anyway, I did try to find a manual for this one before and failed. I hope you have better luck. Thanks, again,
Marilyn
Clarification Request
Posted by wendystech on Jun 26, 2009
I'm not up to speed on your particular model/ brand. Just giving you some general HVAC info. Old time rule of thumb was 12K BTU's for 600 sq. ft. of conditioned space. This is just a general guess-timate. Don 't know about the exchanger you are questioning. Have you tried to locate a manual? Give me model and serial and I'll see if I can't lay my hands on one for you.
Posted by wendystech on Jun 25, 2009
Just some FYI. If unit runs alot and area is humid, could be undersized. Approx. 25% of the cooling is used to dehumidify. Lots of cool air but humidity makes it feel hotter than it is.
Best Solution
posted on Jun 27, 2009
Helpful)
wendystech
Rank: Guru
Rating: 88%, 140 votes
I've been looking for your manual but so far, not luck. I'll keep looking.
If unit runs for long periods of time, it very well could freeze up. Unit will dehumidify any air that is blown over the cooling coil (evap).
Does your unit drip water while it is running? If not, it may be low on freon. Has it ever worked right? I am assuming it is a window unit and not a "Thru the wall" type.
The parent company is Midea-American. Their web site offer virtually nothing but sales pitches. Big waste of time. They work with Toshiba and Carrier but don't know to what extent.
I suggest running the unit one day with the damper in one position and the next day run it in the other position and see if there is any real difference.
Hope this is of some help. Good luck and I'll keep looking.
Comments:
Jun 30, 2009
- Send my the info on the Haier and I'll try to locate a manual for that one too. Might as well while I'm digging for the other one.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE AGQ10AJ Thru-Wall/Window
Questions and Unsolved Problems for GE AGQ10AJ Thru-Wall/Window
Do you recommend GE AGQ10AJ Thru-Wall/Window Air Conditioner?
Answer
Answer
where to place air conditioner in kitchen
Answer
Can you please help? ASTA24LCC split system Airconditioner. The operation and timer light are... (More)
Answer
large amounts of water pouring from aircon head?
Answer
I have the same problem, the manual is useless. !!!! come on LG sort it out
Answer
We had our air conditioner for one year now and it is a Arctic King Air Conditioner, a small window... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in Newport, KY
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
