Question about Panasonic Lumix DMC-FX01 Digital Camera
When i turn the camera on..it says this memory card is protected
How do I fix?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
Write protect
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 19, 2013 | General Electric A735 Digital Camera
When I turned my camera on it said locked how do I fix this
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 31, 2010 | Samsung TL100 Digital Camera
When camera is turned on it says memory card is
If you're using an SD card, it doesn't have a reset switch. It does have a switch to lock (protect) and unlock the card. It should be in the unlocked position.
Jul 21, 2010 | Kodak Easyshare C813 Digital Camera
MEMORY CARD ERROR, CARD LOCKED BUT IT ISN'T LOCKED HOW CAN I FIX IT
Apr 02, 2010 | Canon PowerShot A530 Digital Camera
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
Memory card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Nov 10, 2008 | Nikon Coolpix L11 Digital Camera
Turning on the camera
Please look at the memory card closely. If there is a write protect switch, it will give you this error. Please ensure that the write protect switch on the memory card is not in the lock, or protected position.
See more information about SD cards here.
Let me know if this helps!
Brian
Jan 08, 2008 | Nikon Coolpix 4600 Digital Camera
Cant delete
Well... If it's telling you that it's write-protected, then you most likely have an SD memory card in the memory card slot.
Take this card out of the memory slot. Inspect the memory card for a small, white tab on the side of the card. Notice that this tab slides up and down. Move it in the opposite direction of it's current position.
Insert the card into the camera, turn it on and see what happens then.
Keep in mind that the camera also has built-in flash memory. If it wasn't the SD memory card, then perhaps there is a setting in the camera's options that was used to write-protect the internal memory as well? (Doubt that's the case with the internal memory, however. Never heard of a camera doing that before.)
I'm sure that checking the mem card and sliding the white tab forward will fix your problem. Let us know.
Cyryl
Nov 15, 2007 | Panasonic Lumix DMC-F7 Digital Camera
Memory card
There sould be a very tiny slide switch on the memory card itself. See the pic
Sep 17, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
52 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
