Question about Car Audio & Video
I have just acquired Mitsubishi Spacestar not fitted with rear audio speakers. Wiring is in place. Where can I buy the correct speakers and do I need any special fixings?
  • 578 Answers
Yes the wiring are there your to remove the rear panelling to find them
Posted on Jun 25, 2009
I bought a DVD player for my 2006 Mitsubishi Lancer. Thr new unit came with wiring diagram, however there is no information on the original Mitsubishi harness to match wires. The unit has a Fujitsy sticker...
Hi, please check the colors below for a match. If these are not your colors, please get back to me.
2006 Mitsubishi Lancer Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/White
Left Front Speaker Negative Wire (-): Red/Blue
Right Front Speaker Positive Wire (+): Red
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Yellow/Red
Right Rear Speaker Positive Wire (+): Light Green
Right Rear Speaker Negative Wire (-): Yellow/Green
Mar 20, 2011 | Mitsubishi Raider 2006-2007 Car Radio...
How do you replace the radio and insert a cd player?
Hi, pull the trim plate off the dash around the radio. The trim may go all around the instrument panel. With the trim plate off, you can see the factory radio screws. Take the screws out, pull the radio out and remove the connectors, including the antenna wire.
You will need an adapter to fit the aftermarket radio snugly into the dash. They sell these wherever they sell aftermarket radios. I recommend you also buy the cable adapter. If you don't, at least buy the antenna adapter of you will no be able to plug your antenna into the new CD player.
Follow the instructions on putting the adapter together--it's made for a lot of different cars. You need it to screw into your dash where the screws came out.
If you buy the wire adapter, follow the directions that come with it. I recommend you solder the wires, but you can use those crimp connectors if you don't have soldering equipment.
If you don't buy the adapter cable, use the factory wire colors below to match up the aftermarket wires to your factory wires. Wrap any solder connections with electrical tape and carefully plug everything back in, including the antenna adapter and antenna cable. With the adapter plate attached to the new player, carefully push the wiring aside to get the player into the slot and then screw it in. check the system for proper operation and then replace the trim panel.
Enjoy your CDs, and let me know if you have any questions.
2002 Chevrolet Silverado C1500 Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2011 | 2002 Chevrolet Silverado 1500
Wire harness to switch from stock stereo to cd player will not fit the wires that are supposed to? so what wires are the speaker wires
Not sure I understand your question. Did you buy a harness adapter for GMC, or are you trying to just cut the connector off the factory radio and solder it to your CD player? If the latter, below is the color code for your factory wiring.
1994 GMC Sierra C1500 Car Radio Wiring Schematic
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Nov 20, 2010 | 1994 GMC Sierra
Cant seem to axcess the rear speaker screws to replace them.
Are you looking from the trunk to the top of the rear deck? You are correct though in most factory installed audio systems, the size and quality of the speakers is unique and low quality. Generally any aftermarket speakers you buy will have to be bolted using holes that you drill in the deck. Also most car audio place will cut the deck with a saw in order to enlarge the holes for better sound. You may want to consider using POP rivets as fasteners for the new speakers because getting under the glass to use screws can be tough.
Oct 30, 2017 | 2004 Chevrolet Aveo
I cant find a 2001 mitsubishi mirage stereo wiring diagram
Please forgive me, as we are not allowed to copy and paste items, but this is the only details i could find, hoping this helps you.
2001 Mitsubishi Mirage Car Radio Wiring
Diagram
Car Stereo Dimmer Wire: Black/Yellow
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Yellow/Brown
Jan 19, 2010 | Car Audio & Video
I hae a 2002 mitsubishi lancer I need wiring radio
i dont have a pic but it goes like this..
(color1/color2 usually means the wire has a stripe or dots on it)
Car Stereo Antenna Trigger: Yellow
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Oct 28, 2009 | 2002 Mitsubishi Lancer
Wiring diagram 4 radio on 97 mitsubishi mirage
1997 Mitsubishi Mirage Car Audio Wire Diagram
Jul 21, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Car audio
Here are the wire colors and what they do in the system. Please rate my help.
1994 Saturn SL Car Radio Stereo Wiring Diagram
Car Stereo Antenna Trigger: N/A
Jun 16, 2009 | 1994 Saturn Sl
Wiring diagram for audio system replacement? First time replacing a car audio system. I'm OK with wires connections but color codes does'nt match at all.... No diagram found in manual nether on actual...
2003 Mitsubishi Galant Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Black
Car Radio Switched 12v+ Wire: Blue
pls rate
Mar 15, 2009 | 2003 Mitsubishi Galant
Radio wiring
1996 Mitsubishi Montero Car Audio Wiring Diagram
Car Stereo Antenna Trigger Wire: White/Black
Aug 29, 2008 | 1996 Mitsubishi Montero
Car Audio & Video Logo
202 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
