Question about Kenmore 74602 Gas Dryer
Dryer turns on but not producing heat - Kenmore 74602 Gas Dryer
  • 28 Answers
Could be a bad thermostat (I think in these appliances they use a thermistor) you need to troubleshoot with a volt meter.
Posted on Jun 24, 2009
White Knight gas tumble dryer BG 457 starts and ignites with the orange light coming on, works for about a minute producing heat then the orange light goes off. The dryer continue to turn but the orange...
I feel you need a new igniter or thermocoupler. Just remember those igniters are activated many times to keep constant right heat for the machine to do its job.
Jan 25, 2018 | Dryers
Kenmore elite model 11062952100 My dryer will not heat I replaced The thermal cutoff and high limit thermostat the dryer produce heat briefly but is not producing heat again.
There is a high limit switch (looks like a button with two wires hooked to it) on the bottom of the vent frame. When the vent fills up with lent at the bottom it gets hot. For safety, this limit switch will turn heat off. Remove the vent frame and clean it out and check the continuity of the switch. Also, make sure both heater elements are working properly.
Jun 19, 2011 | Kenmore 63942 Dryer
My dryer has power and tumbles, but produced no heat (tested with vent tube off). I reset the circuit breaker and now it produces heat. What is up?
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
Feb 18, 2011 | Dryers
Dryer turns, but there is no heat being produced
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 06, 2010 | Whirlpool WGD5800S Dryer
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
My dryer does not produce heat Model #pcks443eb1ww
Could be a thermal fuse, which is generally the problem. It's cheaper than replacing the whole heating element. Try that first, or you can even test it, if you have a voltage meter.
You can also check to see if your vents are blocked. If airflow is blocked, it can turn off the flame, and not produce any heat. You can take off the vent hose and turn the machine on to see see if you get airflow, or if the ignitor kicks on the heat.
Oct 31, 2009 | GE DSKP233EWWH Electric Portable Dryer
Dryer not producing heat
Check thermostat/ Element....See also if has scut out @ back casing reset
Oct 08, 2009 | Dryers
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Kenmore 74602 Gas Dryer Logo
237 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
