Question about Kodak EasyShare DX6490 Digital Camera
Have new memory card (32G) won't format, was told internal memory is problem but can't seem to erase internal memory to format memory card...Help! R
    Genius:
  • 1,234 Answers
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    How do you erase all images on a Canon IXUS 1100 HS camera?
    If all the pictures are on a memory card, format the memory card. If all the pictures are in the internal memory, remove the memory card (if installed) and format the internal memory.
    Formatting wipes out all information from the memory card or internal memory and prepares it for further use. This is better than deleting individual pictures and will help prevent future troubles.
    Nov 27, 2012 | Canon PowerShot ELPH 510 HS / IXUS 1100 HS...
    How do I clear the internal memory?
    This should do it - this comes from the manual Formatting will do what you want.
    Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
    Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
    Brand new camera, inserted the flash card, formatted per instructions. I take a picture but I can't play anything back. It does not record pictures on the flash card. If I remove the flash card and use...
    On some cameras, once you use the internal memory, you must format it and completely erase it before a regular memory card will work. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, never use the internal memory again.
    Feb 17, 2011 | Intova CP9 Digital Camera
    Kodak C160 camera says internal memory full. How do I correct it so it will take a pic? Have tried new memory card.
    You need to get rid of the pics in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert the new card and do the format thing again to erase and initialize the card. Everything should work properly now.
    Jan 26, 2011 | Kodak EasyShare C160 Digital Camera
    Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
    1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
    2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
    Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
    I have taken 8 pictures with my camera and we had put in an 8gb memory card, but my camera says internal memory is full. this is a brand new camera, and I am learning about it, but why is the memory...
    Apparently, you used the internal memory before putting in the memory card. Now the camera only wants to use the internal memory. Here's the fix...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert the memory card. If this is a new card, you will need to format it in the camera, too. If there are any pics on it, download them first using a card reader if necessary, because the card will be completely erased.
    Jul 27, 2010 | Kodak EasyShare M530 Digital Camera
    Brand new memory card
    I have the same problem with the same camera. I checked other sites and it seems that the C330 takes only SD cards up to a max of 1GB. It won't read SDHC cards and it won't read SD cards greater than 1GB.
    Jul 03, 2010 | Kodak EasyShare C330 Digital Camera
    My kodak camera keeps saying that the internal
    The internal memory is small. Your camera will continue to write to it until you erase the pics from it. Here's how...Remove the memory card. Download any pics you want to save from the internal memory. Go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Insert your card. It should work properly now. Promise yourself to never use the internal memory again.
    Apr 29, 2010 | Kodak Easyshare C182 12MP Digital Camera
    Hi everyone, I just bought my camara last night and added a memory card. The camara now is saying that the internal memory is full, and I have only taken 1 picture? I'm hoping you can help me, please?...
    You need to get that one pic out of the internal memory. Here's how...remove your memory card. Go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your memory card and do the "format" thing again to erase and initialize the card. Everything should work properly now.
    Apr 18, 2010 | Kodak EASYSHARE M340 Digital Camera
    "Internal memory requires formatting."
    This error message indicates that the internal memory in the camera requires formatting or is corrupt. You must format the internal memory. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a memory card during formatting may damage the card. (Formatting internal memory also erases email addresses and album names. To restore addresses and albums, see Kodak EasyShare software Help.)
    Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
    Kodak EasyShare DX6490 Digital Camera Logo
    137 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
