Question about Kenmore HE2 Plus Front Load Washer
My kenmore washing machine will fill up for about 3 seconds. Then stop. What could this be?
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My Kenmore washer would not stop filling with water. i checked and the pressure sensor hose was of the switch, i rehooked it, but it still does not stop filling with water. do i need to do something...
Hello.
Kenmore washer come in a variety of s and styles,including extra-large dishwashers and dishwashers that are accessible for thedisabled.
A Kenmore washer automatically resets itself every time a washingcycle completes.
If you want to reset an Kenmore washer in the middle of acycle, you can easily do so. Resetting a Kenmore washer takes only a fewseconds to complete.Instructions.
1 Press the"Start/Stop" button.
2 Hold the buttonfor three seconds and release.
3 Select the program and options on the frontpanel you want the dishwasher to use. Press "Start/Stop" to restartthe dishwasher. You have now reset a Kenmore washer Thanks.
Jul 30, 2011 | Kenmore Washing Machines
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore model 8566645 Washer is connected and runs but water flows out of the bottom and not into the tub.
Remove the front and side panels if you haVE TO. Look for a bad water pump most common on older units.
The fill tube to the tub from the fill valve is a second likely problem
I water filter located under the tub and in line with the water pump is also a possibility.
A bad hose is not likely but a connection to a hose could be a problem.
Jul 10, 2009 | Kenmore Washing Machines
Kenmore Washer 48102 starts filling then stops
the pressure switch should be tested for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer stops after fill
You should control the pressure switch on the machine. It is a circular object on the top of the machine, and it is connected to the drum with a thin hose. Remove the hose from drum and blow the the hose, you shuld hear 2 or 3 ticking sound from the switch. If you can not hear, change it with a new one. Also clean the thin hose, it can be blocked by detergent.
May 28, 2009 | Kenmore Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
22 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
