Question about Compaq Keyboard
Which 3 buttons are directly left of the spacebar?
Which 3 function buttons are directly left of the spacebar? My daughter has picked the top off and I don't know which goes where alt, windows symbol, Fn.
  • Pedro Jesus
    Pedro Jesus May 11, 2010
    What Model of COMPAQ is yours ?
    President:
  • 1,901 Answers
Most Compaqs have the following to the left of the space bar:
Ctrl - Fn - Win Symbol - Alt
However some have this layout:
Ctrl - Win Symbol - Alt - Fn
If you post the model # we could say for sure.
Thanks for using Fixya.
Posted on Jun 25, 2009
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
I need to know how to use a function on one of the keys (near top left). It has 3 icons on the key. Can you help?
you might need to press the key just to the right of the spacebar to access the third character
Apr 17, 2011 | Acer NSK8458AN Keyboard
Where is the internet button on an hp 67306 keyboard
If you hold down the Function key (the third key to the left of the spacebar), and, while holding that key, press the F3 key on the keyboard, your web browser should start.
Mar 19, 2011 | HP Pavilion dv7-1132nr Notebook PC
I want to change the number of rings, from three to four or five.
Pick up the handset.Without turning on the handset,press the function button near the bottom numbers.After you press it,you can cycle through the options with either the directional pad or hitting the function button again.Different makes have different methods.Once you get to ringset,I think the directional pad will change it.Right for more,left for less.Ithink once you select a number and move on it sets for that number.It will tell you what to press to set it if that is not correct.Hit the function button until you exit the system.Good luck!
Aug 06, 2010 | Vtech Cordless 6041 Phone
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 29, 2009 | Swintec 7040 Typewriter
Spacebar key wont click back on
get a new keyboard...those springs that need to go under the keys if you loose them they never function the same.
Feb 14, 2009 | Compaq Presario C700T Notebook
How do i reset my timex ironman
There are only 4 buttons. One of them will put you into "reset" mode, but which one? Before you guess, here is the trick: you have to hold it for a couple of seconds (you don't want it resetting accidently, right?) Ok, so start with your 1st guess (ok, pick top left) did the display give you any clue that was the lucky button? (ok, the display --the seconds, will not increment, but instead will just flash the same number) You are over the hurdle...if not try another one of those 4 buttons. Once you get the seconds to flash, you now have to somehoe reset whatevaitwas you needed to reset. Which means you need to pick another button...such fun! Pick the bottom right one and look for the hour display to flash (if the light comes on, this is the wrong button...you know that) and once it does you have found the "mode" for resetting the hour. So only a couple of buttons left: pick one to see if it increments the flashing hour hand (if the light comes on...you know what to do) and push it till you like the hour number. Then push the first button that started you on resetting this thingie to let the watch know you are done messin with it.
Now you are set to fix your daughter's watch...or your grand-daughter's watch...You B so smart now...you can fix anything!
Jul 03, 2008 | Timex Watches
Projector operating
Hi there
If the signal is not picking up do the following:
Right click on your desktop and go to Properties - then click on settings and check if your resolution is set right i.e. - a XGA (1024 x768 ) Resolution on PC and Laptop.Or SVGA ( 800x600)
Then click on the advanced settings tab and check if your secondary screen/monitor is attached - needs to be attached.
If this still doesn't work then hold in the Fn ( function ) button - situated on left side of your spacebar and press the button in your F-row of buttons with the 2 screens on it.
This should do the trick
Apr 02, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Trouble with output to the projector
Hi there
Check the following on your laptop.
Right click on your desktop , go to properties and settings - check if your resolution of the PC is the same as that of your Projector. i.e. 800x600 or 1024x768
Also check that your secondary monitor is attached / activated.
If the signal stil won't pick up - hold down the Fn ( function button) left of your spacebar and press in your F-row of buttons the one with 2 screens on it. ( differs from brand and model )
Hope this helps you and good luck with your class tomorrow !
Mar 31, 2008 | Toshiba TDP-T9U Multimedia Projector
Projector
Hi there
If you are using a desktop PC you should check if your secondary screen/monitor is activated by right clicking on your desktop and going to properties - then go to settings and advanced settings.
You'll see a block with two screens in it A & B . Attach the secondary screen.
If you are using a Notebook - do the same as above.
If it doesn't pick up the signal on it's own , hold down the Fn ( function ) button - situated left of your spacebar and in you F-row buttons press the one with the 2 Monitors/Screens on it.
Fn must be held in when pressing the F button - Very Important !
Hope this helps !
Nov 12, 2007 | Office Equipment & Supplies
Compaq Keyboard Logo
165 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
