Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
The pump on my system stopped working for a few days and now the water is really green. Would the pump clear the water back up when its running again or do I need to add something to the water to help it. And if so, how long would it take to get the water clear again approximately.
    Habit-Forming:
  • 17 Answers
Get the pump going and add 3 jugs of liquid chorline and let the pump run overnight. The next day clean the filter and add 2 more jugs. This will get you into shape until you can test the water and get exact needs from your local pool supply store.
Posted on Jun 25, 2009
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
I have an Intex Krystal Clear Saltwater System, model CS8111. My problem is green water. I had been out of town for a few days and when I came home the pool was green. Also the low salt light was on. I...
If your salt is at the correct levels required for your pool and your still getting the "91" code on your LCD screen do not add more salt you need to clean the plates on the chlorinator. Look at your manual and it gives you instructions on how to remove, clean, and replace the chlorinator section on the pump. Reminder, if your PH and/or alkalinity levels are off you'll be cleaning the plates often because of the scale build up. I personally run my pump 4 hrs daily and I have never had a problem with green water however, once it did become cloudy (white) I began treating with algaecide and changing filter every 3 hrs. It cleared it right up. I love the Krystal Clear System.
Jun 26, 2011 | Intex Automatic Salt Water System for ...
This is my first time having a pool and connected the salt water system with filter that came with the pool and water started turnung green. the salt water system was set for 2 hours was this enough? Got...
Green water is copper and/or mag being impacted by the CL.
Three ways for you to go ... dump the water and refill. Get a sequestering agent to remove the metal ... follow package instructions.
... let the CL go to zero (make it go to zero) and then apply the sequestering agent ...
... do nothing ... the metal will eventually get filtered out.
I suggest you run your filter 24/7 until this problem is cleared out.
If this is a gunnite pool, you should be concerned with metal staining. Get your water balanced which means you should head for these goals ... in this order. CAL = 250 - 300; ALK = 80 to 120 (100 is good); METAL = ZERO; pH = 7.2 to 7.8 (7.4); cyanuric acid for outside pool) = 60 to 80. Don't expect to achieve thiese goals in a few hours. This will take a few days to achieve.
If you found this response to be helpful, the courtesy of a positive vote will be appreciated.
Thank you for your interest in FixYa.com
Aug 25, 2010 | Intex Automatic Salt Water System for ...
After I vacuum the pool, backwash it and then turn the filter system back on it blows in a lot of green water back into the pool. What should I do?
1st Green water is algee. Kill the algee in the pool. 2nd when you're finished backwashing the filter. Stop pump and move valve handle to rinse position. Then restart pump. Run in rinse mode until glass is clear. Then stop pump again, and move lever to filter position. When you're backwashing, you're reversing the flow of the water through the filter. When you switch directly back to filter, anything left loose in the filter flows back to the pool. When you select rinse, it reverses the flow back to normal, but keeps the water going to the waste outlet until clear, that way that green puff of water will go out the drain. You can get complete manuals from www.haywardnet.com
Jul 20, 2010 | Hayward SAND FILTER, PRO SERIES
We have green algae in the pool do I have to drain whole pool ?
Diane,
you are in a mess
The intex pumps are not big enough to clean any size pool
Your best bet is to invest in a sand filter and pump what I will explain next works for either the sand or the intex only difference is it wont happen again with the sand
Here are some basics you- need to turn a pool over 3-4 times in a day every day so using generic numbers since i do not know your gallons if you have a 5000gl pool and a 2000gl pump thats 7 hours of filtering remember that is bare minimum
It is also very crucil to keep your salt at 3000ppm any lower and you do not produce enough chlorine any hiher than 3800 and you can go cloudy no lower than 2800
You also should be using 2 extra chemicals once a week
non foaming algaecide per directions for your pool gallons
and water clarifier if you keep the filter cartridge system
this takes minute particals and make them stick together thus making them bigger and easier for the filter to trap otherwise you have a lot of little particles that get through the paper filter
you should also have 2 cartridges one working while the other is drying
A dry filter to start with works better than rinsing yours and putting it right back in
I also run my filter 24/7 if I am not generating I am filtering
Chlorine consumption happens for many reasons sun heat rain sun tan oil # of swimmers and so on so it is a good idea to use a stabilizer to help hold the chlorine this is only a tool to help you will need to figure out with the situations I discribed how long to generate sometimes its 4-6 hours sometimes 12 just depends on how much chlorine you started the day with and what elements were present
Now to the labor and time intensive task at hand
Clean your cartridge now shock the pool with 2 gallons of liquid chlorine
2 gallons of bleach is also fine for this application
Run your filter for 12 hours and then clean the filter now turn it back on and brush your pool walls and bottom
not the brush that is probably under your vacuum head but a real pool brush you must use a lot of elbow grease
let settle for a few hours and vacuum
clean out the filter and continue this method till it clears up
After the first vacuuming you can add the non foaming algaecide I mentioned and once close to clear start with the clarifier
once you are back on track you should get the second filter and change them out every night
I have used this method for this being my 4th season and have never had any thing other than clear water
Jul 09, 2010 | Intex Automatic Salt Water System for ...
I purchased an intex saltwater system, hooked it up, been running for 3 days now, and it has turned my pool water GREEN!!!!!!
It, did not turn your pool green. The pool was ready to turn green before you installed the intex system.
before having the system did you regularly use stabilizer? non foaming algecide? How long do you filter? There are so many variables. I will try to make it as easy as possible
We will address the salt system last right now you need to get your pool back to normal
Start by shocking it with 1-2 gallons of liquid chlorine let filter run during this time to stir it up
after 12 hours you need to brush the sides and bottom and then let settle
Now vaccum and then clean your cartridge with a strong blast from the garden hose
Start filtering again and at this point add the non foaming algaecide
the next day brush again and let settle vaccum again clean the filter again and continue this until the pool is clear
once it is clear you will want to use the algaecide once every 5-7 days.
Now a little fyi
Intex filters can not support the gl ph that is needed to keep a pool clean and crystal clear. All of there pumps are under rated for the gallon of pool that is sold with it
A pool needs to be turned over at LEAST 3 times in a 12 hour period
I will use generic #'s
If you have a 5000 gl pool and a 2500 gallon pump that is 6 hours minimum filtering time you do the math for your pool
You should also run the pump continuous. It is the only way to really filter efficiently with an intex pump
now for your generator
Although a good concept it is really a waste of money.
All the salt system does for you is to make it so you do not need to add liquid chlorine or tablets but you still need to add chemicals as mentioned above
get a test kit for salt water the ones that read #'s not color
get the salt to 3000ppm no lower than 2700 or you will not be able to produce enough sanitizer and any more than 3800 and the water tastes terrible and will usually trigger an alarm for high salt
once your pool is clear shoot for this
now to maintain it
Although you may be told otherwise this is what has worked for me for this being the 4th season with no green ever
I filter 24/7 with generating chlorine any where from 4-12 hours depending on the day.
chlorine consumption is created by many factors # of bathers heat sun rain people sneaking in with sun tan oil and so on you will need to figure out what is best for your situation
Dont forget to get a good stabilizer to help with holding the amount of chlorine in the pool usually about a pound per 5000 gl
as mentioned I also use the non foaming algaecide just follow the directions for your gl pool
I also use a water clarifyer that turns minute particles into larger particals that the filter can actually catch
and even though the filter may not look dirty clean it every day.
I use 2 one in the unit and one drying
Spray it out hard and let it dry overnight
Dont ask me why or how but a filter that is dry from the start filters better than a wet one put back in right away
Had you been doing all of this since you opened the pool the addition of the salt system would have worked fine
Good luck
Jul 07, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Pressure up past 15 or 20 shortly after
The sand is clogged and needs a backwash or change.
May 25, 2010 | Hayward Pro Series 18" Above Ground Pool...
Green water
Chlorine generators raise your pH over time. You will always have to monitor and, on occassion, adjust your pH down using acid. Your water being out of balance likely lead to the green water condition.
Check your alkalinity first and adjust it if needed. Once it is stable, adjust pH using acid, then get your pool shocked to kill off the algae. You made need an algacide too but save that for last and only if required.
Jun 16, 2009 | Intex Automatic Salt Water System for ...
Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Jun 02, 2009 | Intex Easy Set 1500 Gph Filter Swimming...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
150 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
