Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
I have a proline 2hp above ground pump. A snake
I have a proline 2hp above ground pump. A snake got caught up inside an around the shaft. I have removed the snake, but the shaft will not turn. When I switch it on it just makes a humming sound. Any advice?
    Problem Solver:
  • 12 Answers
The impeller is still jammed you need to get it cleaned out. You can try with a pair of needle knose pliers if that doesnt work your gona have to remove the pump bolts that hold the motore to the pump pod. Remove the bolts around the motor and seperate it this will give you better axcess to the impeller. Clean it out and try to move it if the impeller will not spin freely with the debris removed the motor has burned up .
Posted on Jun 26, 2009
How to repel snakes from my home
Robin,
I have heard that moth balls put around the outside of your house can be effective. I am getting ready to try this myself since my wife caught a snake inside our house this week.
May 30, 2015 | Bonide Snake Stopper Repellent
Proline 2hp pump not getting water pressure
make sure top seal ok if ok check intake union make sure tight check impeller for debris
Jun 30, 2012 | Pentair 2hp 230v Ur Mh Challenger High...
I have a proline de 1.5 hp above ground pool filter. How much de do I put in the filter? Thanks
one pound of D.E. for every 10 square feet of filter area, there should be a data plate on the filter telling you what the filter area is.
Jul 30, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
I have a Waterway 48-Frame 2HP 115v pool pump for my above ground pool. I just purchased it about 2 weeks ago from Rec Warehouse. It was working good no problem for about a week and half then all of of...
Check to see that the pool pumps mounting is secure. Loose mounting could cause the motor to run loudly. It could be bearings rubbing or a bent shaft. If it is new, this should not have happened. If you check the mounting and feel that it is secure, I would return the pump to an authorized Waterway service agent and let them look to see if the bearings or shaft are damaged. I would do this quickly while you can still return the pump if its defective.
Jul 04, 2010 | Waterway Spa Pump (Side Discharge) 1 HP...
How can I tell if my noisy Hayward Super 1hp pump noise is in the motor or the pump?
99.9999% OF THE TIME its the bearings going bad, and need t be replaced asap.due to a bad shaft seal... search your area for your local pool pump motor repair guy with free testing. should be around $75 to repair it if caught in time.. here in florida lizards,frogs,grass and snakes and the such get into the motor and you can get that grinding sound but it will soon fade, but can restrict airflow and make your motor run hot and fail prematurely.. so if the noise doesn't fade in say a hour or two.. have it checked .. here is how to remove most pump motors just click on this link.. hope it helps ya .. jay florida
Jun 22, 2010 | Hayward 1HP Super Pump II Inground Pool...
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
465 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
