Question about Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore 1 Speed Automatic Washer stops after the wash cycle. It is still full of water, but will not rinse, drain or spin.
  • 2 more comments
  • karenzndalla Jun 24, 2009
    This problem is with a Kenmore 1 Speed Automatic Top Loading Washer, not an Elite Oasis.
    This machine is NOT an Elite Oasis - it is a 1 speed automatic top loading washer, about 1 yr old. It does not drain, rinse, or spin after washing.
    Oh, ok. The washer is at my daughter's apt - will go over there to check it out and get back with you. Thanks!
  • karenzndalla Jun 26, 2009
    Yes, replaced the lid switch today and the washer works great! Thanks!!
    Sergeant:
  • 353 Answers
Sounds like the lid switch is not working
Posted on Jun 24, 2009
  • 15,935 Answers
Your timer/controller board has failed.
Please use the "Continue with this expert" option and reply with the full model # so I can link you to the parts.
Thanks!!
Posted on Jun 25, 2009
  • 400 Answers
It is caused if you put too much amount of water and cloths at one cycle .. it can also be the posibility that you might have not set the timer properly or have not set it to 2 way spin .. thanku for consulting
  • Azum Saeed Jun 24, 2009
    OK get its Motor checked it must have been effected by water while washing or have got burned because too much load at once..
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore Elite Oasis 27052 Top Load Washer Logo
111 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
