Question about Sony Xplod XM-554ZR Car Audio Amplifier
Cd works and has sound but no audio when in Fm or Am mode
    President:
  • Sony Master
  • 1,114 Answers
If it's just static, it's probably a bad antenna. If there's nothing it may be a bad tuner. If you visit a car audio shop and slide the deck out for them without disconnecting it, they can plug in a test antenna to verify your problem. Hope this helps
Posted on Jun 24, 2009
My AG-V3050 pro-logic receiver seems to have a volume control issue. The test mode volume works fine but when I switch it to fm the sound is very weak, I have to crank it all the way up to get a little...
Hi
Two dump question and than recommendation..
  • First ;During listening FM ,Your " MUTE" switch is "ON" or "OFF" ? if not how about plain STEREO mode ? did you try it ?
  • Second..how about the other Modes , i.e ..CD ,DVD etc. ? same problem or it happens only in FM ?
ok..now the possible solution;
sometimes FM stations do not properly triggers pro-logic circuit and cause such problem and you need to switch to STEREO or A.F.D mode to listen FM (AFM includes sub woofer)..
This is true for FM only and it should not happen in other modes as DVD ,CD,Phone etc..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 29, 2011 | Teac AG-V3050 Receiver
Hi, I have installed my JVC radio and when it is on FM radio, there is sound through the speakers, but when I play a cd there is no sound.
are you using an amplifier? if so, it sounds like you are using the blue wire (power antenna remote) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. when leaving tuner mode the power antenna wire is turned off.
Feb 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do I go from "Protect: mode back to FM play on
The word protect will engage when you have output problem and will shut the audio off so no sound is available, however if the sound is working normally with protect visible then there is clearly processor issue, something I have never seen before. But it should be checked by a qualified tech.
Dec 29, 2010 | Sony LBT-LX50 CD Shelf System
HOW DO YOU USE THE MODE BUTTON AND WHAT DOES IT DO.I DO NOT HAVE THE MANUAL
the mode button is to run am fm radio,may have 1 am mode and 3 fm modes.this is to switch from am to fm also helps in memorizing stations on am/fm.also can put you in the cd player mode.
Dec 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
RADIO/CD WORKS BUT NO SOUND FROM FRONT AND REAR SPEAKERS WHEN SWITCHED TO SPEAKER MODE. PROBLEM STARTED WITHOUT ANY WARNING SIGNS
Most likely vibration damage to the radios audio circuit. Contact Iron Cross Audio for repair options. www.ironcrossaudio.com
Jul 26, 2010 | Harley Davidson 426290 AM/FM Radio
RCA rs2600 every thing works but the radio.When the source is switched to AM or FM no sound comes from the speakers.The sound works fine with the CD or tape.
Try to clean the selector mode switch with a contact cleaner like "electra"that safe to all surface plastic or metal.If still the AM and FM not working.You better replace the selector with identical rating parts.
Hope it may helps;
DON'T FORGET TO RATE:
RegardsVOTIT
Jun 12, 2009 | RCA RS2600 CD Shelf System
Connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Feb 28, 2009 | Onkyo HTR500 Receiver
Sony Xplod XM-554ZR Car Audio Amplifier Logo
77 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
