Https://www.google.nl/?gws_rd=ssl#q=intel+845ge+motherboard+specifications Google
SOURCE: my audio driver not updated intel 845ge
You should be able to use the Realtek AC97 HD audio codec with your board.
Post your results back here...
SOURCE: I keep losing date and time which causes some
That's exactly what is wrong.
You will need a new battery.
SOURCE: connecting sata hdd on 845ge
Directly you can't, the chipset on that motherboard doesn't support SATA. You will have to buy a PCI SATA card and plug the disk in it.
SOURCE: I have just re-installed Win
Hi.. Have a friend download the driver from the motherboard manufacturer's web site ( or use a different computer). Then you can burn the LAN driver and others to a CD or put them on a usb "pen drive." Hank
SOURCE: I can't install xp sp2. configuration is intel
if the last message is performing cleanup or something like that. And you never did run disk cleanup in your harddrive you might have lots of unnecessary files at TEMP, Temporay internet files and etc. folder. thats why the installation looks hanging, to check if your PC is hangging or reading open the Task manager and see if its processing... or there are numbers moving around.
also look the RECYCLER folder if the size is suspecious. (2GB or more)
