Question about Mitsubishi VS-5043 50" Rear Projection Television
Big Screen Televison problem
My timer light is blinking constantly on the front of the television. I have the 50 inch mitsubishi Diamond. I have already tried the reset button and the light goes out for a second then come right back blinking constantly. Please help We have the same problem. The green timer light blinks fast and cannot be reset. There is no response to any front panel nor the remote. Pressing the reset button causes the timer light to turn off until the reset is let go. Then it goes back to constant blinking (does not stop after 1 minute as the manual states). It looked like expert had an idea but .. I looked for the self-diagnosis and couldn't get anywhere on the live chat. Any help????   CGB
  • 1,694 Answers
Re: Big Screen Televison problem
1) pull chassis ( requires un-hooking extensive wire runs)
2) turn chassis upside-down
3) solder any / all bad connects,esp. regulator pins
Look for electrolytic capacitor leakage evidence =
dark,discoloration of trace material
4) replace any bad capacitors
5) re-install chassis and test
Posted on Nov 05, 2007
0 characters
3 Points
Wd-65831 status light constantly blinks
have you tried a new lamp? part# 915P049020
web site:
I strongly recommend the original part# as many replacements will not work properly in a Mitsubishi.
May 16, 2015 | Mitsubishi Diamond WD-65831 65" Projection...
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Wd-52525 HDTV Stutis light constant red
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi Big screen problem
Blinking Problem
replace DM
May 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power supply problem either the horizontal output or regulators are most likely shorted.
Jan 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 65 inch Diamond rear projection
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Need to try self diagnosis, it's here in threads. If not you need live chat!
Oct 01, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Projection Televisions Logo
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
