Question about Panasonic KX-T7633 Corded Phone
Clock on Phone
How do I reset the time on Panasonic KX-T7633, it is 26 minutes slow
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 201 Answers
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Posted on Oct 19, 2009
How can i set the date n time in Panasonic TX-TGA542AL cordless phone?
This is how to set date and time on panasonic KX-TGA542AL.
Press the "Menu" key.
Use the up and down arrow keys to select "Date and time." Press "OK."
Enter the month, date and year using two digits for each on the keypad.
Enter the hour and minute in 12-hour clock format using the keypad.
Press the asterisk (*) key to toggle between "AM" and "PM."
Press "OK" and then "OFF."
Regards
Jul 12, 2011 | Panasonic KX-TGA560 Cordless Expansion...
How do we keep our Panasonic KX-T7731 from changing back to night mode? I recently reset the time and every time I do it changes to night mode. How do I permanently set my phone system on day mode?
This has about 5 different conditions, so let me start somewhere.
Pretending your 7731 is connected to a recent Panasonic KSU, like a TA series, you have the ability to set the time by hand, or CID delivered in the first call after 2 or 3 AM will do it. If the sender is still on standard time (typical with VoIP delivered CID), then it will reset the clock to a different time (-1 hour) every day and it will be noticed if you set the clock and the first call of the day follows.
In addition, via programming from the main phone, you can set manual or automatic switching for day, night, and lunch modes. That procedure is outlined in the Programming Manual for your system, but it involves setting the clock times in Maintenance console 1.4 or programs 006 and 007.
If you absolutely want to never have to deal with clocks or night mode, then set 006 to manual and dial 781# on the intercom from the main phone (x101).
Note that this is only the solution for TA series KSU's.
Mar 17, 2011 | Panasonic KX-T7731 Corded Phone
I need to change the time on my clock - Panasonic KX-T7730
There are a few types of phone sytems that work with the kxt 7731. these instructions should handle most of them.
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set.
1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000
4.- Press "SPEAKER" button
5.- Press "FORWARD/DND" button to change to the hour selection
6.- Press "TRANSFER" button and enter the hour
7.- Press "FORWARD/DND" button to change to the minutes parameter
8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter
10 Press "MUTE" button to select AM or PM
11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed)
12.- Press "HOLD" button
13.- Press the "PROGRAM" button on the face of the phone
Nov 02, 2009 | Panasonic KX-T7730 Corded Phone
Time is wrong
The time is set from the master phone (usually 101) by the 000 command. Your system installer should have given you the access sequence to get there.
Carl
Jul 31, 2009 | Panasonic KX-T7433B Corded Phone
Change the time on the clock
For the KSU model TDA50, TDA100/200, TDE or NCP.
From the main phone or manager phone default ext. 101 enter prog, *#1234. Then dial program code 000, select enter, Use the up down pad to move the cursor enter your time and date select enter when finished. Then Exit on the screen .
Jul 28, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Jul 28, 2009 | Panasonic KX TG5100M Cordless Phone
My clock is wrong on my Panasonic KX-TG2650N phone.. How do I fix
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done.
Please rate this answer if it was helpfull.
Thank you.
Dec 27, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7436 - time/clock
Hi Juliana, to set the time and date you leave the handset on-hook, Press program * * and the user password ( default 1 2 3 4 ), display shows USR - PGM NO?, dial 0 0 0, press next, enter 2 digit year ( to change current entry press clear ), press arrow pointing to the right, press select until month is displayed, enter month, press right arrow, enter day, press right arrow, press select until day of week is displayed, press store, press next, enter hour, press arrow, enter minutes, press arrow, press select for am or pm, press arrow, press select for 12 or 24 hour format, press store, press end. Let me know how it goes. ...Mike
Aug 13, 2008 | Panasonic KX T7436 Corded Phone KX-T7436
The time on the LCD is wrong
If you are looking at the manual for the phone itself this probably is not covered because the phone system stores the time, not the phone. I do not know which Panasonic phone system you have. Here is a helpful link to a page that contains time programming changes. http://www.tel-programmer.com/time_setting.html
Nov 10, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
155 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
