While getting post screen I press DEL to enter in bios has no effect!!!! I have resetting the CMOS, getting cmos default loaded, For info: it's possible to boot from HDD (XP) and OS is working fine. The problem is just entering into the bios setup!!
Not all boards use the delete key, try these alternatively f1,f2,f5,f12 let me know if you have any luck! cheers
Testimonial: "Thanks Chris, I have try these keys also! no result. All the keyboard keys are working fine (tested under XP)."
is it a wired keyboard or wireles
Hi, Chris of course I swap with an other kbd. The bios inside
is latest (1.16). Thanks for your help Chris.
The BIOS information is typically found at or near the top of the POST screen
ALR PC non / PCI = CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
hope this helps
I have try these keys also but no result.
It's a wired kdb. I think this mobo is out.
i'm trying to eliminate simple possible fault at first, have you tried a different key-board? and one other thing i noticed on their w/site was, updating the bios themselves,, although this can be risky!!
