Question about Pedals Electra Retro 1/2" Cruiser Bike Bicycle
Crank knocks on my electra hellbilly when i pedal hard
  • 34 Answers
The Electra Hellbilly has a three piece crank/bottome bracket. There are many things that can cause a knocking noise on your bike. I will give you a few places that you can check but you may need to take it to your local bike shop.
1st. Check the pedals. Take a 15 mm open end wrench or pedal wrench and makes sure the pedal are tight. Also check the pedals for any play in the bearings or tight spots. If they seem to have any issues, try a new set of pedals. Test ride.
2nd. Make sure the crankarms are tight. Use a 14mm socket wrench. You may need to remove a cover over the nut with a small flat head screwdrive. If you have a torque wrench, they should be between 25 and 35 ft lbs. Test ride.
3rd. Check the chain tightness. It should have just a small amount of play in the chain. Also check the chain for tight links or bad links. Do this by either flipping the bike, putting it in a stand or having someone hold the rear of the bike up while pedaling and watching for the chain to not flow over the cog in the like the rest of the links. If you find a tight link you will have the work it loose by hand, going back and forth with the tight link your hand and lubing it with something like tri-flow. Test Ride.
4th. The last two solutions are better off adjusted but your local bike shop. You need to check the bottom bracket and rear hub. We can start with the hub. While standing over the rear wheel, move it side to side. If you feel any play then your hub is out of adjustment. Adjusting the hub requires cone wrenches so unless you have the tools it will be less expensive to have it done. For the bottom bracket, grab one of the crankarms and move it side to side, if there is any play here then it requires adjustment. Once again it requires special bicycle specific tools so it would be less expensive just to have the repair done.
Hope this helps. Let me know if you need any other help. You can contact me at elijah@starbikesfl.com. Thank you
Posted on Jul 18, 2009
HUSQVARNA TRACTOR AFTER ADJUSTING DECK HEIGHT ENGINE TURN KEY ENGAGE BRAKE PEDAL ENGINE WILL NOT START UNTIL PEDAL IS MOVED BACK N FORTH CRANKS AT A CERTAIN POSTION ?
sounds like you may have knocked the safety switch out of its position. check to be sure they are in the correct position and are still hooked up to the wire plugs.
Nov 13, 2016 | Husqvarna Garden
2002 chevy trailblazer has a hard time cranking up, but when it does it runs for like a secound or two sounds like its knocking or somthing then dies can any body tell me what might be the problem
Could be crankshaft position sensor or mass air flow sensor or some other sensor ! The only way to tell is to have the vehicle hooked up to a professional grade scan tool that can view engine data parameters ! Your best bet is to take it to a ASE certified repair shop or the dealer !
Aug 08, 2015 | 2002 Chevrolet TrailBlazer
Wont crank
There is a switch on your brake pedal which is for safety and will lock out the starter if you do not have your foot on the brake pedal when you try to crank the engine.
Your brakelights will not work as well, so you can verify the switch problem by observing the brakes.
The switch could be just knocked out of place or it could be broken. This is a common problem across all brands of Ford, for those years using this system.
Feb 12, 2014 | 2001 Lincoln Navigator
C846 hard to pedal
follow this instruction. God bless you
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Jul 21, 2013 | Precor C846i Experience Series Commercial...
No start no crank
Check and see if the brake lights work. There is an interlock system. The idea is to prevent runaway starts and some work by preventing the starter from cranking and others work by preventing shifting without a foot on the brake pedal.
If the switch on the top of the Brake pedal lever or clutch pedal on stick shifts is broken or knocked off its' holder, the signal will not go through. For those units, the loss of a signal on Automatic transmission equipped cars can be diagnosed by looking at the brake lights. Stick shift models will need to have the wiring leads tested with a Voltmeter.
May 31, 2013 | 2011 Ford Escape
2003 Nissan xterra...couple problems...timing belt just changed...knock sensor, crank shaft positioning sensor, distributor cap all changed...service engine soon light keeps coming on...took to...
Had same issue with (re: crank position sensor) on a 2002 Kia. Had all the same work done as you, only to find out with was one of those Kias with a manufacture defect in the block where the crankshaft keeper key slots to lock crankshaft in place in block. The block half of the slot had worn and the crank shaft itself kept slipping out of time. Is it throwing any codes? Gas pedal linkage may well just need a good cleaning and lubrication.
May 02, 2017 | Cars & Trucks
Electra hellbilly how to loosen back wheel to tighten chain. How do I loosen the shifter side of the back wheel to move the wheel back to tighten the chain?
You need a 15mm metric wrench, boxed type preferably. We use Craftsman in our stores, they are the best. Also, do not loosen just one side, loosen both, then adjust it and tighten. If, you are unsure take it to your dealer, who will be more than happy to help you.
Sep 26, 2010 | Cycling
Knocking motor sounds 2005 5.7 Hemi Grand Cherokee 38,000 miles
knocking? or pecking? check the knock sensor but if it is a hard knock sorry to say but you have a bad crank shaft and worn bearings
Jan 14, 2010 | 2005 Jeep Grand Cherokee
When i crank my 96 taurus sometimes it floods out and wont crank.
Too much gas won't make it hard to crank. To thick oil or not enough antifreeze will. If it's flooding, slowly pump the gas pedal to the floor 3 times and then with the pedal held tight against the floor, crank the engine. This will open the butterfly wide open and will blow the extra gas out.
Jan 02, 2009 | 1996 Ford Taurus
Pedals Electra Retro  1/2" Cruiser Bike Bicycle Logo
353 people viewed this question
Top Pedals Cycling Experts
Marvin
Marvin
ray gallant
Alec Oren Orris
Level 1 Expert
Are you a Pedals Cycling Expert? Answer questions, earn points and help others
