Question about Sony KV-27S65 27" TV
Assistance for a match for flyback
I have a samsung tv model no: ct-5029v and serial no: 3cbf501202 which have a flyback fcm-20a025 which is bad i however have a new flyback number which is fsv20a001 i want to know if fsv20a001 as the same pin configuration as the bad one and will it work. i appreciation your quick response.
    Problem Solver:
  • 14 Answers
Re: assistance for a match for flyback
Is the original flyback number: fcm20a025? I work in a shop repairing televisions, might have a good spare I could send you.
Posted on Nov 22, 2007
0 characters
3 Points
What's the flyback number of Samsung CRT TV model number CT-15N30MJ?
FCM2014FL / FCM14A025 If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. .
Apr 26, 2015 | Samsung Standard (CRT) Televisions
Panasonic CT-32HL43G
Hi my name is Aleixo. I have problem with this set. When I star fix it, it had oppend the mais fuse, I replaced it and I start usin one serial boolb light to save the fuse. It has some shurt but I can't find it. I think: Flyback, Vertial IC, Video IC but like fine, I desconnected the demagnetizer coil. It istill with shurt. I don't have schematic. If someone know please I need help. Thanks
on May 09, 2008 | Panasonic CT-32HC14 32" TV
What causes a blown fuse in tv samsung
Usually in a Cathode Ray Tube Television a blown fuse is either something is wrong in the high voltage power supply section or the flyback transformer is bad, or a bad horozontil output transistor.
Nov 18, 2013 | Panasonic CT-36G34 36" TV
Looking for Part Number : KFT6AW45SF
There is no such FBT to Pansonic. Contact the nearest authorised service center for Panaonic at you town for details.
May 11, 2012 | Panasonic CT-32SL14 32" TV
Panasonic TV - no picture, but sound is ok
resolder flyback transformer contacts on the board, if doesn't help, replace flyback and horizontal output transistor
Oct 06, 2009 | Panasonic Standard (CRT) Televisions
Call union electronics at 1 800 648 6657. Have your model # and possibly a chassis # or board #. Are you sure this is the problem? A bad flyback is kind of rare but they do happen. Good Luck!
Sep 04, 2009 | Panasonic CT-20G21 TV
Panasonic ctp2780sf Picture very dark
check the ABL at the flyback and solder any bad connections there. U can increase the brightness at the flybacks buttom control .
Dec 29, 2006 | Panasonic CT-27SF25 27" TV
TV does not turn on
I'm looking for the same info... my CT-32sx12f is completely dead too. I was wondering if the IC regulator or the flyback is bad. Fuse is fine. Anyone have any wisdom or experience on these sets they can interject? Thanks!
Sep 05, 2006 | Panasonic CT-32SX12 32" TV
Hitachi Multisystem TV model # C2980FS ..not powering on
First off you gotta tell us whats the right model and make as you have two listed here and both of these flybacks are avail. trough The parts are not listed online but get the toll free # or leave a message for them to get back to you. Now A flyback is not a user replaceable part for starters. It is soldered in and theres very high voltage inside these sets even after they are unplugged, and its not adviseable to replace a hi-voltage part in a set, unless you know the issues involved with replacing such parts. Good Luck
Jun 17, 2006 | Toshiba 35AFX54 35" TV
Sony KV-27S65 27" TV Logo
144 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
