Question about Lanier Office Equipment & Supplies
NETWORK ERROR MESSAGE
I recently changed the IP address for the Lanier LD015SPF and now the printer continues to flash: Check Network Settings (103), How can I stop this? Also when trying to make copies it will only print one copy at a time if I choose 10 15 or 20?
  • auntboo2 Jun 24, 2009
    I got the Network Error Message to go away by Changing the Gateway address.
    The multiple copy problem is still there. Have not changed any drivers lately
  • 555 Answers
Hello my friend, regarding on your problem, try to check again your network settings. Reevaluate its setting such as IP and network connection try to check it. Also try to reinstall and reconfigure your Lanier LD015SPF to ensure the operational and functional capability of your printer. If it does not work properly you can refer to this link below for more actual trouble shooting
Try to download this printer manual solution PDF format file: http://www.lanier.com/downloads/manuals/BW_MFP/ld015copyreference.pdf  In this site you can find lots of solution.
Or you can find someone or a technician that can help and configure or fix the problem in your printer in actual. In that way, he can fix directly to the problem and can teach you how to handle such problem again if in the future may arise. Also it directly addresses your problem and can you can sae time.
Hope this will help address your problem. If you need more assistance just contact me or reply to this post. Thanks
Posted on Jun 25, 2009
  • Jonas Awayan
    Jonas Awayan Jun 26, 2009
    Did you try the solution i posted? If not then kindly try that solution.
    Thanks
    Brigadier General:
  • 3,917 Answers
This error comes if you have the drivers curropted by some chance. Did you install any software recently that might have disturbed the drivers.
Please find the user manual and the link where you can download the drivers:
http://www.devicemanuals.com/guide/Multifunctional/Lanier/Lanier-LD015spf-Multifunction-Operating-Manual-==TVRReU5UVTE=.html
and
http://driverscollection.com/?H=LD015&By=Lanier
Thanks for contacting Fixya
Posted on Jun 24, 2009
WHAT DOES IP CONFLICT ERROR MESSAGE MEAN ON A DELL 2335 PRINTER
This means that another device on your network has the sames address as your printer, if the address of the printer is fixed / manual then you will need to find out what other device is using the address and restart it.
Mar 10, 2011 | Dell 2335dn Multifunction Laser Printer
Lanier LD016 can't scan to server using server name but can scan to server using IP address on server 2003.
Your DNS information may be incorrect use a ipconfig /All to check your DNS setting from any workstation on your current network. If you ping the name of the server it should reply with the IP address
Feb 13, 2010 | Office Equipment & Supplies
When scanning, received error message "selected servers are not found. Consult you network administrator." Never received this error before, and as the administrator, I have not changed any settings.
If your network is set up to DHCP your leases may have expired and your server may have given new IP Addresses to the destinations you want to send to. Check in the settings of the MFP (copier) that the IP address matches what the IP Address (check at the computer as well) on the computer is. When all else fails (including reboot of all) reinstall the software.
Oct 27, 2009 | Sharp MX-2700N Color Copier
Reset Dell 1720dn network address to get back access to it?
Please have a look if you have Dell 1700 series laser printer. Please follow the instruction bellow to reset printer to factory default: 1. Power Off the Printer from the back switch from the back 2. Open Front cover 3. Hold Down “Continue” & “Cancel” button while turning printer on
se http://digg.com/hardware/How_to_Reset_Dell_1700_1700dn_1710_1710dn_1720_1720
Regards Anders.Thornberg.Qnetcom.se
Dec 28, 2008 | Dell 1720dn Laser Printer
I followed this suggestion and now the IP address is 0.0.0.0. I can not get to the printer setting. I don't know if the DHCP setting still remained as static instead of dynamic. ANY SUGGESTION?
I had the same problem, after removing the DHCP settings, maybe for an error during the configuration the printer didn't assume the new IP address and it resulted 0.0.0.0 from the configuration page.
No way to connect to the printer until I did a network card reset following this procedure:
7. Network Card Reset:
a. Turn the printer off.
b. Open the front cover.
c. Hold down the Continue and the Cancel button while powering the printer on.
d. Release the buttons when the Error light (bottom light) stays on solid.
e. Close the front cover and the printer should return to a READY state.
f. Press and release the continue button to print a network settings page.
g. On the page that prints verify the following:
�� Status = Not Connected
�� Active = Yes
�� DHCP,BOOTP,RARP Enabled = Yes, Yes, Yes
�� Address Source = Manual
�� Address = 0.0.0.0
The printer took a new IP address from the DHCP server.
Since my goal was to set a fixed IP address, I entered the printer configuration through Internet explorer, typing the newly assumed IP address and going to TCP/IP settings where I removed The 'Auto DHCP' and I set the IP address I wanted.
Oct 20, 2008 | Dell 1710n Laser Printer
HP LASERJET 3055 Manual IP Address not saving
Try flashing the firmware: one of the fixes is this - (Improved IP address management of DHCP to Manual changes).  See link below. Firmware
Gerben People tend to evaluate events in light of their paradigm rather than evaluate their paradigm in light of events.
Sep 27, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Printer not working Error offline
I recently resolved the same problem by going into the Printer and Faxes under Control Panel. Look for the printer icon that shows in offline status. Right click 'Properties' and go to the Ports tab folder. Select the Port IP address in question and click on 'Configure Port' button. Click on the check box next to SNMP [SNMP status enabled] to remove the check mark and to disable the option. Click OK on the Configure Port window. Click Close on the properties window. Hope this helps.
Apr 17, 2008 | Office Equipment & Supplies
Printer busy/or error
Sounds like your machine is using DHCP, not a static IP address?
Print your network settings from the Printer, then try to Ping from a computer on the network.
Check the Network setting of the machine, make sure it is set to a fixed (static) IP Address.
If this is the problem, you can go into your PC printers port and change the port to the reassigned IP Address of the machine.
If you reinstall the drivers then you will have this installed twice, one will work one will not, so delete it from the printers folder before you reinstall before you reinstall
Sep 28, 2007 | Sharp AR-M277 Black and White Copier
168 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
