Amazon Kindle Paperwhite Logo
B
Bill Kramer Posted on May 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does the battery level icon show only a "lightning strike" symbol?
The battery level icon shows only a "lightning strike" symbol; why?
Shanaka Jayatilake
Level 2:
  • Expert 36 Answers
  • Posted on May 24, 2014
Shanaka Jayatilake
Expert
Level 2:
Answers
36
Questions
5
Helped
6334
Points
109
Lightning Strike Symbol means that the battery is charging.
If it is shown even when it is not charging then your charging circuit needs to repaired. Just replace the charging IC not a very high cost. Might cost around 5-10USD.
I have a brand new amazon fire 7 and am trying to set it up. First how can I see how much my tablet is powered up? And how do I connect this device to my internet?
Charge it. Press and hold the power button. If shows a battery by itself it's dead and it's not charging. If it's a battery with a lightning bolt symbol it's dead and it's charging. If it turns on, go to settings, find wifi settings, turn wifi on, find your wifi network, and enter the password for your wifi.
Can't charge ipad
Plug it in to the AC outlet via a charger.
Wait for an extended period of time...then try to turn it On.
Does your iPad turn on ?
If so, what is the battery level shown by the battery icon at the top of the screen ? Does it have a lightning bolt in the middle, showing that it is charging ?
if nothing happens, your iPad battery may be dead.
Take your iPad to an Apple astore to have it replaced.
I just bought my tablet and it will not let me do anything. I reset it. Nothing. I downloaded games and I cant find them to play. What is wrong with it as its brand new.
HI Brittney
What tablet did you purchase? You have 2 questions here, so I will answer the 2nd one first.
You downloaded games and can't find them? They are usually loacted here... click Settings/Apps/Downloaded.
The first question, depends on what tablet it is.. Samsung ? Apple?
Have you tried plugging in the charger and wait a few minutes for the tablet to show the battery is charging? (on the bottom right there is a battery icon) It should show a small lightning bolt as its charging. If not... take it back to the place you bought it as it's NEW and they can replace it if it's faulty.
2answers
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
What does the lightning bolt inside the battery symbol mean on the screen of the digiland tablet dl700. It wont charge
That symbol means that the tablet battery is plugged in and is supposed to be receiving charging voltage. If the battery is bad, it may not charge but the tablet will still work with the charger plugged in.
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Trash icon
The trash symbol will only show up when you push and press/hold the icon you wish to delete....as soon as you have pressed the icon long enough the trash icon will show up on the bottom in the middle of the screen...then you drag your icon you wish to delete to the trash icon.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
