Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
When I observed this issue, I found the freezer not running the defrost cycle enough times, (maybe this was in the spirit of conserving energy Energy Star compliant???))
If the Defrost is working, use the diagnostic test, that may be all you need to do until the next build up of frost on the coils.
Has anything changed in the cooling? Can you locate the model number on your refrigerator.The noise is coming from under or inside the refrigerator or freezer? Let me know those few things and we will find out whats going on, Thank, Sea Breeze http://servicepartstec.blogspot.com/
Can you tell me if you hear the compressor running under the refrigerator? Is fan running beneath the refrigerator? Need to get the exactKenmore model number found when you open the fresh food section. Let me know, Sea Breeze
probable reason for this is that the thermostat controls freezer temp and freezer follows suit.
if temp in your garage is low ie in winter, then the fridge doesn't need to switch on and the freezer temp rises.
i know this sounds barmy but it is true
