Question about Lenovo ThinkPad X200 Notebook
Blue Screen in docking station
I'm getting a Blue Screen from a IBM Lenovo X200 while its in its docking station. The laptop boots to the OS correctly when booted outside of the docking evironment. I am currently running Hard Drive diagnostics..and I will swap the memory..Any ideal why this is happening?
    Sergeant:
    Champion:
  • 253 Answers
Try going into your BIOS and setting the hard drive from your Docking Station as the primary boot device (1st on the list), then your laptop hard drive
Posted on Jun 24, 2009
Docking station usb ports are not working -laptop is lenovo x240
Hi
If all other ports on your docking station are working then this would point to either a hardware fault on the DS or with the DS drivers on the laptop, I would also make sure you have seated the laptop on the DS correctly as this can sometimes cause some ports to appear not to be working correctly
Cliff Cook
MCP
Aug 01, 2014 | Lenovo Ibm Thinkpad X24 Piii 1.13ghz 128mb...
ThinkPad T410 Docking Station Not being Recognized
Change the BIOS to reflect output through dock(external Monitor) first.
Jan 05, 2012 | IBM Lenovo ThinkPad T410 Notebook PC
Added a ST95005620AS in Lenovo (2503) docking station as a second drive and it is causing a slow boot in Lenovo T60
Very strange, I added a WD 500GB in place of my CD drive in my R60 and have had no issues. I suggest the following:
1. Pull the Seagate drive from the docking station, does the laptop boot faster (confirm the added drive is really the problem).
2. Put the drive caddy back in with a drive with one of another brand other than the Seagate, see if the performance imorives (confirm its the Seagate which is the problem and not the caddy or docking station).
If performance increases in both cases, do some research on compatibility issues between the IBM and Seagate drives. I would also go to Lenovo's website and update the laptop BIOS... this can easily be accomplished by downloading a tool and doing it through Windows. I had issues with using a non-Lenovo battery with my R60 till I updated the BIOS. Good luck, let me know if you get to the bottom of this. Please rate me if this helps you. Thanks.
Jan 04, 2012 | IBM Lenovo ThinkPad T60
Docking station USB ports are not working - Laptop is Lenovo x201
I unplugged the moniter, mouse keyboard and power. I plugged in the mouse, keyboard, moniter and then the power. I placed the laptop on the docking station and it worked.
May 02, 2011 | IBM (250410U) Docking Station for ThinkPad
I have lenovo x200 7458e77 notebook th promlem is that my me password is locked since i had gotten it second hand . i also have an in built fingerprint reader which used to work for the past 6 months but...
http://ja.axxs.net/x200.htm this is the solution for all Thinkpad laptops... thanks ...
if u dont want buy that device...
i have one more free solution
check this site .. download pony prog... and make com port ... u can do same thing http://www.lancos.com/prog.html#hardware thanks...
Sep 13, 2010 | Lenovo ThinkPad X200 Notebook
Machine reboots when it is hot docked
This sounds like a common feature of the T60, when docked it requires a reboot also try to reboot 2-3 time a day to help cooldown. IBM is a quality machine, even go as far as buying cooling extention for the T60.
Apr 29, 2010 | IBM (250410U) Docking Station for ThinkPad
I have ibm G41 laptop i formatted my inbuilt os ...but i have to access that os and ibm access menu again recovery space is still in my harddisk but i cant access ibm acceess menu ...
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. thanks and have a nice day J-
Mar 19, 2010 | IBM ThinkPad G41 Notebook
When I install the driver and the computer restarts I get a blue screen that tells me a fatal error has occured and windows will not start normally. The only way to get past this screen is to restart in...
When you install the drivers, are you installing them while the laptop is conected to the docking station? If so, try installing with docking first. Then after installation, shut down your computer. Dock the comptuer, then start the computer back up. If you get a blue screen, go into your bios and make sure that your USB setting is set to High Speed.
Please make sure that the docking station is plugged into your notebook before booting up, there is an issue that all expresscard docks share with plugging the docking station in while the notebook is powered on.
If there is a switch located on the Expresscard
On-Pre-boot support
Off-Post-boot support (Default)
This switch is used to determine how the dock is recognized in the
system at boot up stage. Certain notebooks will detect the dock and not
work properly during a pre-boot mode (ie. trying to boot up on the
external VGA device, not the internal VGA of the Notebook). This was
observed in notebooks (Fujitsu, some Sony and Toshiba models) that
use a BIOS developed by Phoenix Technologies. If you experience
such issue, please turn the switch from the default "OFF" position to
"ON". You will only need to set it once.
Jul 23, 2009 | Targus ACP50US Docking Station
Lenovo ThinkPad X200 Notebook Logo
1,407 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
