Question about GPS
POWERS UP DIPLAY FLASHES WITH A BEEPINGTONE - GPS
  • 32 Answers
Maybe the problem of display,you can go and buy a display.
www.keyuda-lcd.com
contact
kingyijin@hotmail.com
ICQ:597322520
Posted on Jun 28, 2009
Diplay powers off
Check your socket or plug. Must be loose.
Jan 10, 2014 | Hoover Washing Machines
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
HD56W66 powers on screen flashes foe a few sec.
On your Deflection board Look for Bad capacitors CP150 2200uf 16v CP114 CP120 in same circuit they will be puffed up on top if they are replace all 3 capacitors.other 2 are 220uf 35v and 330uf 35v
Mar 17, 2010 | RCA HD56W66 56" HDTV
88883888 this is diplay if i press all 8 numbers on hp10bii. What could be wrong? Perhaps week batteries? Please help
While it could be weak batteries, and that is a good start, it sounds like the LCD display is becoming "unbonded" from the flexible circuit that powers it. If you feel comfortable with electronics, you could carefully open the calculator and push on the flex circuit (looks like a thin piece of flexible plastic) where it attaches to the LCD display. Use a soft object such as a pencil eraser to do this.
Mar 10, 2010 | HP 10bII Calculator
Megellan 3100 will not diplay the map in map mode. All other features work. The unit powers up OK. Can access menues and other screens. It appears to have a problem with the internal data base as well....
Often a hard reset does not help in this type of problem You may need to reinstall or redownload the maps data as it sounds like it has either deleted itself or become damaged
Jul 28, 2009 | GPS
Green light flashes 3 times, but never powers on.
Most probable cause is the CP150 and the CP120 and CP114 capacitors. You can get the replacement capacitors with instructions at the following link under RCA parts category.
http://servicemanuals.vstore.ca/
Jul 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Smoothfitness 7.1hr would not run
Sounds like the motor is stuck or bad. Get into the front panel near the roller and remove that cover and check it with a volt meter
May 16, 2009 | Smoothfitness Smooth 5.45 Folding...
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Powers down after start up
over load on the power supply/poss. power/convergence or shorted video ic on the crt neck board.
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
GPS Logo
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
