Question about Samsung SGH-t819 Cellular Phone
T819 lcd display problems
I also have lines and solid white screen most of the time.
The lowest pricing I have seen for the LCD replacement part is $69.99.
Anyone know where to get this part cheaper?
SOURCE: lcd screen
close the screen a bit and then push it in a little bit..fixes my problem every time
Posted on Jan 03, 2008
josh1856
  • 105 Answers
SOURCE: Replace LCD Screen
the replacement LCD will cost you about 45$ you could just go pay $50 to get it fixed from the store even if you do not have insurance. there are probably some little black/grey dots covering the screws/hex once you get those off you should be able to get the cover off after that its pretty easy.
Posted on Jan 26, 2008
silveraxe
  • 66 Answers
SOURCE: Samsung SGH-D600 LCD screen replacement
if u still need the instructions on how to open the phone n replace the lcd msg me, but i suggest u buy a working new LCD first
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: LCD screen is totally white and absent of color
Sounds like a loose ribbon cable -- the one that connects the screen to the circuitry inside the camera.
Try squeezing the body of the camera near the bottom 'Samsung' logo, to try to snug-up the connection. Brace the front (under the lens) with your index fingers, and press firmly with your thumbs on the back over the logo just under the screen.
You might try squeezing around the other edges of the screen for good measure in case something else came loose.
-Fionn
Posted on Jan 03, 2009
  • 98 Answers
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Posted on Feb 06, 2009
I have an Emachine D620 5133 Laptop that the screen stays solid white when powered up, any ideas?
No ideas
Just definite facts
Problem is;
A) Graphics chipset
Or.
B) Video Cable
Or,
C) Screen Inverter
Or,
D) LCD screen
Diagnose
LOT of reading ahead.
1) Graphics chipset:
Connect a VGA monitor to the blue VGA port, on the right side of the laptop.
http://www.geeks.com/largePic_all.asp?invtid=D620-5133-OB&pic=D620-5133-OB-box.jpg
This is a general example of a VGA port (Connector), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA Cable.
Turn the monitor on. If a CRT type allow it to warm up
By factory default settings the display should show on the external monitor.
IF not;
There are at least 3 display options;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the Same time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
No display, (Or solid white), on external VGA monitor, suggests problem with graphics chipset. If this is the problem post back in a Comment.
Good display?
Problem is Video Cable, or inside the Display Assembly.
(screen Inverter or LCD screen)
There are no eMachines D620 service manuals, available on the internet for free that I have seen. Supposedly a few paid for versions, but I have my reservations about that.
(Probably a Generic User Guide, which you can get for free)
I also have never worked on this model yet.
But this isn't rocket science, and this isn't 'my first rodeo'.
2) Video Cable:
The Video Cable plugs into the motherboard, in an area under the Keyboard, and under the Palm Rest Cover.
Judging by;
A) Top View of motherboard,
http://www.ebay.com/itm/eMachine-D620-Motherboard-48-4BC01-011-MBN240100-08226-1-Yukon-MB-/121076931939?pt=US_Motherboard_CPU_Combos&hash=item1c30bf5d63
Set your mouse cursor in the middle of the photo. This enables the Zoom In feature.
Looking at the rectangular metal plate, with the opening in the middle of it; come from the Top/Left corner.
See what appears to be a fairly long white strip?
That is where the Video Cable plugs into the motherboard.
Now here is the D620 with the Keyboard removed. (And Display Assembly),
http://www.ebay.com/itm/eMachines-D620-Motherboard-CPU-base-assembly-/110847874891?pt=Motherboards&hash=item19cf0c574b
Here you see the white connector again.
Middle, and towards the Top; in the small rectangular opening.
The Palm Rest Cover has to be removed, to access the Keyboard Cable's motherboard connector. This connector.
Going on....
The Video Cable then goes up by the left Hinge, and then up into the Display Assembly.
From there the main portion of the Video Cable, connects to the back of the LCD screen.
There is also a separate small cable, coming from the Video Cable; that connects to one side of the screen Inverter.
Example of the Video Cable,
http://www.ebay.com/itm/eMachines-D620-LCD-Video-Cable-50-4BC03-021-/130862506637?pt=US_Video_Cables_Adapters&hash=item1e7803628d
The white connector you see at the bottom, with the black pull strip; is the motherboard plug connector.
The small cable extending to the Right, connects to the screen Inverter.
The large connector shown at Top, connects to the back of the LCD screen.
Just from normal repeated opening, and closing of the laptop; the Video Cable may become pulled on, and/or pinched.
This can cause a loose connection at the motherboard side, or LCD screen side.
Screen Inverter cable connection may be pulled loose also
Can also cause damage to the Video Cable. Stretched/Broken wires
The procedure is to;
A) Remove ALL power. Remove the AC adapter (Charger), and Battery.
B) PHYSICALLY check to see if the motherboard connection is tight. Try to plug in tighter.
Reinstall power. Turn laptop on see if this was the problem.
No?
Remove all power again. This time remove the Display Bezel, and see if the Screen Inverter cable is connected tightly.
At this point it is just going to be a visual observation, and record.
Next is to check the LCD screen connection of the Video Cable, and it may loosen the Screen Inverter connection, anyway.
[The plastic frame in front of the LCD screen is the Display Bezel,
http://www.ebay.com/itm/eMachines-D620-LCD-Screen-Bezel-41-4BC01-001-/300798380595?pt=UK_Computing_Other_Computing_Networking&hash=item4608fb0a33 ]
If plugging the connections of the Video Cable in tighter, does no good; the Video Cable is then checked for continuity.
A multimeter is used, and set on OHM's. (1K)
Electricity is sent through each wire. The reading itself isn't as important, as just seeing IF there is a reading.
No reading indicates stretched/broken wire.
You can take the Video Cable, down to the nearest small computer repair shop; and have the resident tech check it out for a few bucks.
The Video Cable MUST be ruled out as the problem, before going on. Otherwise you may be buying parts needlessly.
(LCD screen? Around $70 to $100. You have seen the price of a Video Cable)
Video Cable proves to be good? Go on.
3) Screen Inverter:
The screen Inverter is located behind the Display Bezel, and mounted to the bottom of the LCD screen. (Screen Frame)
To test a screen Inverter requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
Do to this, the ease of access to replace, and the general low cost; the screen Inverter is just replaced,
http://www.ebay.com/itm/LCD-Power-Inverter-Board-for-eMachines-D620-Backlight-Replacement-for-Screen-/120819595221?pt=US_Laptop_Screens_LCD_Panels&hash=item1c2168b7d5
If this doesn't repair the problem, the problem is the LCD screen.
Replace.
I can guide you, and I believe step by step; if you wish to attempt repair.
Post back in a Comment.
Regards,
joecoolvette
Mar 16, 2013 | eMachines eMD620-5133 Notebook
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
Nokia e72-1 white display
Hope it's the LCD Display problem if not the pata that connect the board and the LCD (display or screen)
Please try by replacing the (LCD)screen.
Note: If you can't fixed it by yourself then please refer to the nearest mobile service centre. (Cos' the LCD price is high)
Thanks for using FixYa!
Sep 27, 2012 | Nokia E72 Smartphone
Green line on lcd monitor screen
Unfortunately, a solid line that runs across an LCD screen is due to failure of the display panel, and the only way to repair it is by replacing the display. There is a large amount of electronic driver circuitry built into the display panel, and when something fails it can leave a row or column constantly lit (white or some other color) or constantly dark. There isn't any way to get at that internal circuitry to fix it, so all you can do is replace the entire display.
Dec 02, 2010 | Samsung Computers & Internet
Last night i used my laptop and it is still in good condition. I was surprised when i opened this morning, there was already a straight white line that is seen horizontally on 0.25cm from the topmost area....
It might be the problem of the LCD display wiring. Not any problems of the drivers. If your notebook is still in the warranty period, call the customer care and they should fix it.
Or else print screen, copy it to paint. If there is no white lines in the image, then sure its LCD problem. Replace the wiring with experts in case you're out of warranty period. Take care not to repair it by yourself as it could do more damage to your screen.
Apr 17, 2010 | Dell Inspiron 9100 Notebook
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
Can the lcd screen be replaced?
i have the same problem here. i sat down on my camera Doh! It need a new LCD screen, for sur, and i have a line whit a black/purple spot on the LCD. I open my camera and i separate the screen from the other part (white light) and i search instruction to continue the repairing, i can send photos of what it's look like, well im searching further instruction to replace the LCD screen.
Oct 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Benq lcd Displays only white
Most often the all white screen is the result of a missing voltage to the LCD panel. We usually find an open fuse on the panel circuit board. Unfortunately replacing the fuse does not usually fix the problem.
Mike
Mar 02, 2008 | Computers & Internet
Samsung SGH-t819 Cellular Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
