Checking for items in 'sump' of Hotpoint WMA63
I want to check whether my engagement ring is caught in the 'sump' of my Hotpoint WMA63
  • 31 Answers
Hi you need to pull the washer out. tip it up and at the bottom ov the drum there is a black pipe from your drum to the pump its big on the drum and sall end is your pump end take it off at the drum end and look in there if not try takeing your pump off not that hard to due hope you find it stuart
Posted on Jun 24, 2009
We have hotpoint wma63 on draining and spinning water on floor seems to appear
well I would look for a loose or damages hose fitting while it is working .
Feb 22, 2015 | Hotpoint Washing Machines
Where would an engagement ring end up in a jetstream 1200 machine?
Non Diamond Engagement Rings FULL Reviews
Not to reference, these bands usually expenditure higher. Some you select, whether you're in for the infield or non carbon impinging rings, make sure it's a sound she would never wanna miss!
Nov 27, 2011 | Zanussi Washing Machines
Hotpoint wma63 fabric conditioner not draining from the drawer during wash cycles. I've tried a 'service wash' @ 95deg to clean the machine. I've also checked the detergent/conditioner...
Hotpoint wma63 fabric conditioner not draining from the drawer during wash cycles This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 02, 2011 | Hotpoint Washing Machines
Hi my hotpoint wma63 fills with water for a wash, then empties
motor tacho not being sensored...motor or pcb fault...chopper board faulty bottom front right in machine.
Jul 31, 2010 | Hotpoint Washing Machines
My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I had a problem with my washing machine model no. Hotpoint Aquarius WMA40. Washing is going but after full washing water is not going out pls help me
the sump under the machine needs to be cleaned out, most causes of this is the use of color catcher sheets getting caught in the sump.
email me at appliancesdav@hotmail.com
and i will talk you through to fixing it.
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Where are the filters on a Hotpoint Ultima WMA63?
The filter is located at the rear of washer.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage and or obstruction here as well.
Please leave feedback for my solution.
Thankyou.
Jan 12, 2010 | Washing Machines
Cant find filter to clean. not at the front bottom as usual. wma63 hotpoint. thanks
Remove lower panel at rear of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Oct 29, 2009 | Washing Machines
I have a Hotpoint ultima stream washing machine (WMA63) which the light says the cycle has ended but the water will not empty and we cannot open the door, any suggestions??
first to empty the machine--lower the drain hose at the back below the tub into a basin--once all the water is out--wait for about 3 mins and the door will unlock--then check your filter--probably pump prob
Oct 27, 2009 | Washing Machines
Drum won't empty
Check drum something may be caught on heater not allowing water through quick enough, take sump hose off and look onto drum.
Dec 14, 2008 | Hotpoint WMA35 Front Load Washer
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
