Question about HP Officejet 6310 All-In-One InkJet Printer
When I attempt to print on 6310, it goes to fax mode
6310 tries to fax a document sent for printing.
    Scholar:
  • 169 Answers
Go to control panel >printers andfaxes and see which printer is set as he default printer....it is the fax rgt now.....rgt click on the pirnter icon and change it to the default printer.....should work....
Posted on Jun 25, 2009
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
I recieved a fax a few months back that i cannot find it , does the the hp 6310 all in one have a memmory log so i can access the document again?
You can give it a try, hopefully the printer should be able to print the fax log if it hasn't erased it.
Press Setup Button on printer front panel
Scroll to Print Report - Press OK
Scroll to Fax Log - Press OK
Check the fax that you had received on the date and press ok or it may print the fax log present in the printer.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 19, 2011 | HP Officejet 6310 All-In-One InkJet...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Printing out a confirmation page for a document automatically
press FUNCTION, 7, 4, SET, 1, 2, SET, 2, SET, STOP...It will print everytime you fax out a document.
Oct 02, 2009 | Panasonic PanaFax UF-8000 Laser Fax
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Running a report
Press "Setup" button, then "2. Print Report", then "6. Fax Log", then Ok.
Dec 11, 2008 | HP Officejet 6310 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
Faxes being sent but stuck in memory, How do I Print them out?
Printing Documents in Memory: From B640 Manual
Except when you run out of paper, the faxphone will automatically print out the contents in memory when you remedy the cause of the problem.
If running out of memory caused memory reception, adding recording paper and press {STOP} to begin printing the stored page(s).
After printing the page(s) in memory the faxphone erases the documents from memory.
Jan 19, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
HP Officejet 6310 All-In-One InkJet Printer Logo
133 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
