Question about HP Compaq Presario SR2011WM PC Desktop
When I go to boot the pc, it just beeps very loudly. Never boots.
  • 258 Answers
Thats normally means your video card has a fault, especially if nothing comes up on your screen and you just hear beeps
Posted on Jun 24, 2009
    Scholar:
  • 74 Answers
If it's one long, continous beep that will not stop, that can mean either keyboard, power supply, or motherboard.
Get on the internet, and google "computer beep codes"
That should lead you in the right direction.
Posted on Jul 05, 2009
  • margostanley
    margostanley Aug 10, 2012
    Mine did that also. One of the keys was stuck.
2 Suggested Answers
preachw996
  • 1179 Answers
SOURCE: installed memory cpu is making a loun beep and wont boot up
Either RAM is not fully seated or it's incompatible with your motherboard. Try reseating first. Hope this helps.
Posted on Dec 22, 2008
Loud beeping noise on alienware computer
by fb_margostanley.jpgmargostanley Aug 10, 2012
  • Thankk you. I fixed the problem. It was a key that was stluck. but others may want to know that the type of cement I used for the hinge was JB weld. Worked beautifully! thanks for all lyour help
  • If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
    Aug 08, 2012 | Alienware PC Systems Alienware Aurora High...
    Acer 5742g Beep at boot up
    I have a problem that looks like this one.
    At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
    If I press the power button, it stops beeping. When I release it, it starts beeping again.
    If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
    Any clue?
    Jul 26, 2012 | Acer Aspire 5742G
    My laptop will not boot
    angela it sounds like the ram memory has a problem, try remove and replace.
    "Make sure you remove" battery first, touch something metal to remove any static
    from yourself before touching the ram.
    May 22, 2012 | Acer Computers & Internet
    HP xw4600 Workstation Beeps loud immediately when turned on, then does nothing for about 10 seconds and then the cpu fan runs very loud and there is nothing on the monitor. Will not boot at all.
    Seems your MOBO is bad.When MOBO are damage the symptoms you describe is the cuase your PC dont boot.
    If you need more help post back!
    Thumbs and testimonial are welcome!
    Jul 07, 2011 | HP Computers & Internet
    Acer aspire 9300. Get 3 loud beeps when trying to boot. Will not boot.
    3 beeps usually indicate a memory failure. if you have more than one memory module try powering the computer with just one of the memory modules installed.
    Mar 30, 2011 | Acer Computers & Internet
    Loud fast beeps on boot.( Toshiba Qosimo F45 )
    Looks indeed as if the TAB key was stuck or malfunctioning. The most common cause for such behavior is a liquid spilled on the keyboard, a bit of which got between the layers of the keyboard membrane films and causes intermittent semi-short between conductive areas.
    A trace of liquid caught between plastic films is hard to get rid of, as it practically sealed and doesn't evaporate.
    If it doesn't go away, you may need to replace the keyboard, which is not very expensive fortunately,
    Jul 08, 2010 | Toshiba Computers & Internet
    Gateway GT4010 boots then starts beeping and shuts off
    First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
    Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
    My computer won't boot. It just says something
    sounds like your hard drive lost its boot sector. What version of windows is it running? you probably need to boot your os cd and run a repair...give me more details and I can help you more
    Aug 08, 2009 | Gateway Computers & Internet
    Powers on but won't boot a loud beeping begins and won't boot
    try resetting bios defaults
    disconnect all wires in cable and then reconnect them.
    pick out ram
    then put it back
    regards
    -Mayank
    Nov 30, 2008 | Toshiba Satellite 1115-S103 Notebook
    HP Compaq Presario SR2011WM PC Desktop Logo
    369 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
