Question about Sanyo AWM-2800 CD Shelf System
The CD player part will not open
When I try to open up the CD player it will not open, and when it's turned on it will continue to display "OPEN" then it says "door" after a while. It did not play anything inside so I thought that a disc was jammed and opened up the back, took everything out, and it still won't work.
  • nutfuck Jan 07, 2008
    I have the same problem... i had a cd jam and when i finally got it out the damn thing wont open .... haow do i fix this???
  • OatsNHoney Apr 25, 2008
    My cd changer door won't open either. I took the whole thing apart and can see that the gears seem to be having problems connecting and turning, like there's not enough power to move them. It also will sit and spin the CD table around and around. When it does open (with it all apart and me pulling it) it will spin then close without me telling it to. It's fixin' to go in the trash! Surely there's a better player out there. Can we sue Sanyo if we get shocked while trying to fix the dumb thing??
Very nice questions and answer related blog . And also its very helpful for every one to get answer of any question . WWE Mayhem Apk Data Latest v1 1 31 Download For Android 2018
Posted on Mar 01, 2018
2 Suggested Answers
SOURCE: doesn't recornize Cd's and won't play cds
I have a AWM-2700U (3 disc changer) that was doing the same thing. I removed the cover and found that the laser lens for the CD player had come out of it "slot". I cleaned it with alcohol and a cotton swab and replaced it in the slot and it has worked for the past 3 months since. Hope it works for you.
Posted on Dec 07, 2008
Honda 12 odyssey cd player says bad disc eject
The symptoms suggest a CD is jammed inside. You will have to remove the player and open it up to find the problem and correct it.
Aug 14, 2016 | Audio Players & Recorders
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
Cd player wont eject cd
Try this:
Starighten a paper clip and gently push it into the small hole situated usually just below the tray door until you feel some resistance: continue to push gently and the door should open slightly - enough for you to pull it open and reclaim your disk. Make sure the PC is turned off before you do this. You may then find also that the CD tray will co-operate again when you turn it back on.
Sep 10, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
I have a Toshiba SD2019U DVD player and the door won't open. When I turn it on, it makes a rumbling sound and displays "opening", then continues to rumble then changes to "closing" and...
i think there's a broken or loose gear.or someone put something small that stop the door from openning.
you can try to open the unit up and turn the power on
and check what hinders the door from openning.
May 08, 2009 | Televison & Video
Jul 31, 2008 | Sony CDX-M800 CD Player
Tray won't open, no buttons work
Return it. do not open it up or you will void any warranty. There is either a disconnected cable or a logic/power problem. In any case, a new piece should work out of the box.
Apr 10, 2008 | Numark MP-102 CD Player
My CD player keeps flashing (F15) when I try to play a disc.
It means that the laser/motor module is disconnected. Open the player and locate the connection band of the module. It should be orange, about 1 cm wide and it comes out from under it. Push it HARD into it\'s socket. Make sure you don\'t leave sweat or grease on the electronic and test it. I hope it works for you!
Dec 05, 2006 | Panasonic SL-SX320 Personal CD Player
Sanyo AWM-2800 CD Shelf System Logo
359 people viewed this question
Top Sanyo Audio Players & Recorders Experts
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
