Question about Amana 3.2 cu. ft. Top-Load Washer
Amana heavy duty, extra large capacity top load washer model LW3502W. The cold water runs in very slowly, even after cleaning the filter screen.
SOURCE: Amana Heavy Duty Extra Large
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Posted on Aug 20, 2008
jsrock516
  • 5911 Answers
SOURCE: Washer not spinning/agitat
This problem is usually attributed to a broken motor coupling. The following link provides step-by-step instructions on how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is a small 3-piece component that is installed behind the drive motor and couples it to the transmission. It is common for these small couplers to break as they wear out. The key symptom in determining the cause is the fact the washer will not agitate, but still drains. The reason is because your drain pump is mounted on the front of the drive motor and will still run as long as the drive motor is running. The part number is provided in the link I gave you. A replacement coupler can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best price. Make sure you "Search by Part Number" when looking up the part. This shouldn't cost more than $20. If you do not wish to order on line, take the part number I provided and go to your nearest appliance parts retailer. This is a common item they should have in their inventory.
If you have questions along the way, please let me know. I hope you find this information helpful.
Posted on Mar 03, 2009
SOURCE: Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Posted on Jun 23, 2009
  • 1122 Answers
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
Posted on Jul 29, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Heavy Duty 70 Series Extra
If this is a Kenmore Top Loader washing machine, it sounds like you have a broken motor coupling. The washer filling and draining, but no agitation and spin are common symptoms with this problem. There may also be a rattling or whirring sound as the drive motor attempts to engage.
NOTE: If the washer drains, the drive motor is working. This drain pump on this washer is driven by the drive motor.
The motor coupling is located between the back side of the drive motor and the gearcase (transmission). The coupling is used in place of a drive belt, which is why this type of washer is referred to as a "direct drive". The following link explains how to access and replace the motor coupling:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The part number is included with the link and can be purchased at appliancepartspros.com for about $11. I have included an illustration of what the coupler looks like below.
If the motor coupling is intact upon inspection, the other source of no agitation and spin would be the gearcase. The gearcase on these washers is fairly simple to replace. If you narrow it down to a failed gearcase, the next link explains the steps for replacing one:
http://www.fixya.com/support/r699497-replacing_gearcase
I could only find your model number referenced at repairclinic.com. The gearcase on their site lists for about $160 and is listed as item 423.
I could not find any exploded view diagrams of your washer, but the majority of all Kenmore and Whirlpool top loaders are designed with the same direct drive system. You can purchase a Direct-Drive Repair Manual at repairclinic.com for about $20 (Item number 1170635) if you need a guide for reference.
If you have any questions about this repair, or require additional assistance, please let me know. I hope I've given you enough to work with in trying to narrow down the cause of your problem.
Posted on Sep 29, 2009
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Mar 14, 2009 | Amana Washing Machines
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
Jul 07, 2008 | Washing Machines
Water drip into washer, used to gush in. Now water pipes bang, whine
The problem is the 10 cent rubber washer in a shut off valve in your plumbing. The brass screw that holds this washer has corroded and the washer has come loose. It now floats around inside the valve and the water flow can be blocked at one time, whistle, howel and make bangs at another. It could be any valve including the main shut off. You can listen to the pipes but the sound travels, so you are looking for the loudest spot. A new washer and screw could fix it, but sometimes the screw is broken off requiring a new valve stem. Be prepared to replace the whole valve.
Oct 31, 2007 | Maytag Washing Machines
Amana 3.2 cu. ft. Top-Load Washer Logo
356 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
