Question about GE Spacemaker JVM1640SJ Microwave Oven
Need to dissemble microwave oven door GE model JVM 1631 BB 002 to remove spider.
  • chill954 Jun 26, 2009
    thx for the comments, i'll leave it alone.
  • 999 Answers
Remove the inner strip around the door called the choke. If there are no screws visable it just snaps in place and does break if you are not very careful. This will give you access to the screws holding the outer frame piece and handle on. keep in mind, any repairs done to the door will necessitate a RFe leakage inspection. Boil some water on the front burners and cook the little guy and leave the door alone.
Eric
Posted on Jun 24, 2009
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM 1631: Starts working and stops 3 sec later??
your magnetron is leaking RF do not use until you replace the magnetron, it is interfering with the pc board
Feb 05, 2010 | GE JVM1631 Microwave Oven
I have a JVM 1650BB008 GE microwave oven. I am trying to replace the outer door frame and handle, which are broken. I have removed the door and have pried off the choke cover. Now I need to remove the old...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You have to remove the door handle screw(s) and the door handle, then look for subtle clips that may be holding the outer door screen in place.
Some models have two screws holding the door handle, but some have only one. In that case, remove the screw, then you either lift or rotate the handle to free it.
If you still need help, please write me at prototech@usa.net for the service manual link (no charge, no obligation).
Sep 27, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
On the GE JVM 1650 Spacemaker microwave, how do I replace the door?
If replacing the entire door, all that is required is to open the door all the way open and lift straight up on the hinge side of the door. The door will lift off the hinge pins. You may have to remove the upper grill cover (if equipped) on some models for better access. If you have questions, please let me know. I hope this helps you.
Sep 24, 2009 | GE JVM1650 1000 Watts Microwave Oven
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 03, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Microwave JVM 1640 BB - Spacemaker
ARE THE LIGHTS WORKING WHEN YOU OPEN THE DOOR?
DO THE CLOCK WORK? IF YES YOU MAY HAVE A BAD
TRANSFORMER,DO THE LIGHTS GO WAY DOWN WHEN YOU
HIT THE START BUTTON? YOU ALSO MAY HAVE A BAD CAP.
(DO NOT FOOL AROUND IN THIS PART OF THE OVEN)!!!!
BECAUSE MOST TRANSFORMERS PUT OUT ABOUT 2200VAC.
YOU CAN AND WILL BE KILLED IF YOU MAKE A MISTAKE HERE. IF YOU NO NOTHING ABOUT HV. STAY AWAY!!!!!!!!!
Jan 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
220 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
