Question about Logitech Deluxe Access Keyboard
Problem with keyboard
2 KEYS ON MY KEYBOARD HAVE CHANGED
@ appears when the " is touched
" appears when the @ is touched
  • AustinA40 Nov 07, 2007
    When I press shift and 2 to get @ I get " and vice aversa, some other key are affected.
  • platypus Dec 10, 2007
    My keyboard problem is the same, but both a wireless and plug-in one. Only in Windows Express after installing Windows Office 2007
    platypus
  • 42 Answers
Hi
this is a comen problem with key boards what you could try is dissconnecting your keyboard from your PC and restarting you PC when you hear a bleep and a messidge on the screen follow the instructions and replug your keyboard back in another thing you could try is setting your keyboard to the UK setting this might help to
Posted on Nov 05, 2007
Try setting your keyboard to us keyboard setting in control panel.
also use the key next to ALTCAR andCTRL on right side of keyboard this seemed to changed key board, then hit top left escape key.
somehow my @ sign works now??????
Posted on Nov 24, 2008
I have the same problem after installing Microsoft
Office. I now have a new computer and the problem has been transferred, even though I tried a new keyboard. 4/12/07
Posted on Dec 05, 2007
How do I adjust the touch on the keyboad of a HP Pavilion dv7. I have a light touch and have to pound the keys.
I don't think there is a way to adjust the keyboard sensitivity. I know of ways to adjust the keyboards Repeat rate, which is when the keys appear after you press them. Try that and see if that is what you're looking for. Click Start/Control Panel and look for your keyboard in the control panel.
Apr 18, 2012 | Computers & Internet
Keys need hard touch and don't always type or space
sound like your keyboard have a manufacturing defect.to fix it those keys spring have to be changed.
Dec 03, 2010 | Microsoft K5100141 Keyboard
Some keys not working. Some keys need excessive pressure to make them register. Most of the keys are very light touch rubbery keys and so a light touch on the faulty keys mean they do not register
It's time to replace the keyboard -- it's much cheaper than taking the keyboard to a qualified technician, to try to get it repaired.
Jun 01, 2010 | Compaq Keyboard
If i press 1 key it appears 2 keys
You need a new keyboard. The keypress decoder inside the keyboard has obviously developed a malfunction. It is NOT repairable. Buy a new keyboard.
Sep 11, 2009 | Apple Macintosh Keyboard
Keys on Casio keyboard pulled up
I have a Casio CT-648, which looks like a smaller version of yours. I had the same problem, and got brave and opened it up. I took off the back, which takes several screws. Once it was opened up, I saw the keyboard was fastened to the frame in sections of keys. I unscrewed the section with the raised key (I believe it was 5 screws), slid the key section toward the front of the keyboard, and was able to get the slides to re-engage with the tab below it. I now have a smooth keyboard.
Apr 05, 2009 | Casio Portable Keyboard Touch Sensitive...
Programming function keys on Model MX2700
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
Nov 01, 2008 | Memorex (32021435) Keyboard
Keyboard wireless
Oct 23, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Keyboard
No keys on my keyboard work. Cause: This issue is often caused by either a bad keyboard, bad interface board, and/or bad motherboard.
Answer: Disconnect the keyboard from the computer and connect another known working keyboard to it. If this is a PS/2 keyboard and connecting multiple keyboards or a known working keyboard to the computer PS/2 port does not work unfortunately it's likely that the PS/2 port is bad. Because this port is part of the motherboard this will require that you replace the motherboard. Alternatively if replacing the motherboard is too costly or not an effective solution you could also consider using a USB keyboard if USB ports are available on the computer.
Not all keys on keyboard work.
Reference number: CH000305
Not all keys on keyboard work. Issue: Not all keys on keyboard work.
Cause: This issue is often caused by a bad keyboard or software preventing these keys to be pressed.
Additional information: This document contains information about troubleshooting a keyboard that has some functioning keys. If no key on the keyboard is working see document CH000955.
Solution: Verify that the key is not working in more than one application. It is possible that some keys may not be used in all programs. This generally always applies to the Function keys F1 through F12. If not all keys are working in all programs and you have Windows, attempt to boot the computer to a MS-DOS prompt or safe mode and test the keyboard in DOS. Information about getting into safe mode can be found on document CHSFAFE and information on how to boot to DOS can be found on document CHDOS. If it appears that a substance has been spilt into the computer, please review document CH000303. If all above suggestions have been completed or if you are not running Windows, it is likely that the keyboard and/or keys are bad and it is recommended that the keyboard be replaced with a new one.
Read and follow instructions, Please dont for get to Vote/Thank You.
Dec 28, 2007 | Computers & Internet
Hot keys
Nov 26, 2007 | Logitech diNovo Media Desktop 9673120101...
Funtion Keys not working
Oct 19, 2007 | Dynex Wireless Keyboard/Optical Mouse...
Logitech Deluxe Access Keyboard Logo
294 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
