Question about IBM Wheelwriter 30 Typewriter
When i turn on the typewriter i cannot do anyhing. The 1,2,and 3 lights on the bottom right are constantly blinking. is that a sign of something? I'm am using an IBM wheelwriter 1500 by lexmark
  • 46 Answers
This type of problem needs the IBM Service Manuals. This is a self-diagnostic symptom indicator on IBM Wheelwriters. I do not have access to the manuals anymore so I can not tell you what are the likely problems, but I can tell you that you will probably have to see a service tech who has access to the manuals. The manuals step you through a step-by-step process for locating the problem and resolving it. Sorry for the bad news.
Posted on Jun 26, 2009
How do I fix my typewriter? I can turn it off and on, but makes no movement. The 1 and 2 lights on the bottom right side are blinking and that's it.
Try resetting the ribbon and printwheel if that don't work you most likely will have to have a tech take a look at it
Aug 21, 2015 | Lexmark Wheelwriter 1000 Typewriter
ELECTRICITY WENT OUT AND EVER SINCE THE TYPEWRITER 1000 WON'T DO ANYTHING LIGHTS 1 AND 2 BLINKING ON THE BOTTOM RIGHT SIDE, NOTHING ELSE WORKS
This usually indicates a bad keyboard, See my tip under WW1000 or send me your K.B. for a rebuild 100.00..
DickyO
216-216=269-3918
Aug 29, 2012 | Lexmark Wheelwriter 1000 Typewriter
I have an IBM Wheelwriter 10 Series ii typewriter that locks up with the 1, 1 1/2, 2 & 3 lights on the bottom right blinking. It will do nothing else.
If it types at first then locks up try a shot of WD40 on the silver shaft that the carrier slides on, if it still happens the carrier motor will need some to it is located under the case in the R. rear.
DickyO
May 26, 2011 | Lexmark Wheelwriter 10 Series II...
Typewriter beeps continually and first and third lights from the bottom right blink when I turn machine on. Beeping stops after 30 seconds or so, but lights continue to blink and no keys work. I changed...
Be sure the printwheel id properly installed, remove P/W & check for dirt and debris in that area. If you have air in a can try blowin out that area.
DickyO
Jan 05, 2011 | IBM Wheelwriter 6 Typewriter
IBM LEXMARK WHEELWRITE 5 TYPEWRITE NOT TYPING
Be sure the print wheel is properly installed and that there is no debris in the P/W area. otherwise you'll need a tech.
DickyO
May 19, 2010 | IBM Wheelwriter 6 Typewriter
Wheelwriter 1000 beeps when I try to type!
Could be a few things, board, power supply, keyboard or printer.
But there are some things you can check, remove the printwheel and look for debris in that area, unplug and replug the keyboard, if you are really adventurious remove the cover and keyboard and look for paper clips or staples on or under the pc board.
DickyO
Aug 18, 2009 | Lexmark Wheelwriter 1000 Typewriter
Typewriter only beeps and lights blink. Nothing else.
the beeping and the lights are error codes, meaning the machine will need repair
Feb 25, 2009 | Lexmark Wheelwriter 30 Series II...
Wheelwriter 2
1 &2 lights blinking indicate bad keyboard, Check the ribbon connectors on the keyboard, if they are OK see my tip under WW1000
DickyO
Oct 31, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 Problem
The lights blinking indicates an error code, that mean a keyboard error or posibly a problem in the start up procedure. This is a problem that would have to be solved in a repair shop.
Oct 27, 2008 | IBM Wheelwriter 30 Typewriter
No start up
If your WW3 has batteries it must have spell check or printer options there is a small door on the top right of the machine.
open the door and unplug the plug you find there and try it.
Sep 28, 2007 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 30 Typewriter Logo
282 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
