Question about Samsung HCN653W 65" Rear Projection Television
Red/green drooping L top corner
We moved the tv about 6 months ago in the back of a truck but coverved very well to keep out moisture/air.I noticed a red/green ^^^^^^^ line over all of screen. I the last week I noticed the red/green drooping in the upper l corner of the screen, spreading across the top of the screen.Also, the red and green are not overlapping the green is below the red.
thanks, N.Moore
  • joebest Nov 13, 2007
    I have the same problem, i tryed using te perfect focus feature but it only completes 25% before quitting and the problem does not get fixed. I think a Lamp might need to be replaced, any suggestions?
  • tootie01 Nov 13, 2007
    we also have the red/green problem. only it is sagging from the top left corner and also coming up from the bottom right corner, and words are doubled. worked yesterday just fine. turned it on today and not working. also tried the perfect focus, it goes only to 20%.
  • 1,030 Answers
I have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Posted on Dec 18, 2007
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
Green vertical lines in bottom left corner
Apr 22, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Top left corner double picture red and green
you have a failed IC resistor usually you can physically see the bad one because it burns out leaving you to guess what the value was. Hitachi offers a convergence fix kit which has 2 IC's and all approiate resistors.
Sep 01, 2008 | Hitachi 43FDX01B TV
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
65 in.JVC bad picture
You may have a convergence problem that means, there may be convergence ic's bad or related components.
If you know something about tv's, try checking things out.
You can get a repair manual from websites to download.
If you do not normally fix tv's the best thing is to call a tv repair technician.
Feb 22, 2008 | JVC AV-65WP55 65" Rear Projection...
Screen is filled with a circular Red/Green/Blue pattern
The problem will be with the de-gausing circuit, this de-magnetises the tube when the set is switched on from cold, this is a fault you will need to get an engineer to look at ie, not a D.I.Y repair.
Mar 05, 2007 | Samsung TXR2675WH TV
Samsung HCN653W 65" Rear Projection Television Logo
151 people viewed this question
Jerry Greenberg
Jerry Greenberg
