Question about Toshiba 55H70 55" Rear Projection Television
Sound, no picture
I have a Toshiba 55H70 55 inch rear projection TV. It has picture which goes away intermittently. Starts out good usually and picture goes bad. Looked at circuit boards, flyback seems fine. Thought it might be loose connection, checked with no success. Read about IC's, is this a common problem and how can I replace this component? I am an electrician with good electronic repair skills, just need to get an idea of what to do.
  • Anonymous Nov 09, 2007
    i turn on my toshiba tv n i only hear sounds but no picture i want to know wat is the problem
  • Toshiba Master
  • 8,617 Answers
Sounds like you have a problem in the horizontal or verticle deflection circuits. maybe one of the regulators for those circuits. I would suggest getting the service manual so you are better equipped at diagnosing it. You can purchase the service manual at the following link for 10.99. Plus they will email it out to you quickly if you return to the site and request that they email it instead of mail it to you. Here is their link.
Posted on Jan 20, 2008
Toshiba 61 inch rear projection scrambled picture for 10 minutes after power on, then clears up.
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
Oct 31, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba projection tv 50 inch
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Jan 07, 2008 | Toshiba 50H72 50" Rear Projection...
I have a Sony 47 inch rear projection tv that is about nine years old When the set is turned on it has a good color picture but after a few minutes it tuns to a complete green sceen. Can you tell me what...
The green CRT may be intermittently bad or the focus screen block. Certain sony's are common to have bad CRT's. When the screen goes green does the set shut off?
Sep 20, 2009 | Televison & Video
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Jul 06, 2009 | Toshiba 57H81 57" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Dec 16, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 42 inch rear projection TV
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Oct 23, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
