Question about Philips GoGear HDD6330 MP3 Player
When i turn it on it says gogear and it frezzes right there
  • 24 Answers
Reset the player by holding the off-switch and the volume-+ (plus) switch., and as soon as the player shuts off, press and hold the volume- - (minus) switch. Let the Philips device manager do a repair.
If this doesn't solve your problem, do the above procedure again. The computer will see the gogear as a removable hard-drive now, so go to my computer and format it. Disconnect the player, after restarting it go to settings and choose "restore to factory defaults", this will restore the file structure on the drive.
Posted on Jul 13, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
How do i turn off
Slide and hold the button on the bottom of the unit for more than 2 seconds until the unit turns off. You can then slide the switch to the left or right, depending on how you hold the GoGear, to lock the unit and prevent it from accidentally turning on.
Apr 17, 2011 | Philips GoGear SA2RGA MP3 Player
My philips mp3 turns on to the philips screen, but then turns right back off. nothing seems to work such as: restart button, usb, etc.
Hi Are you sure the gogear is fully charged, your problem is symptomatic of a failing or uncharged internal battery.
Sep 30, 2010 | Philips GoGear HDD6330 MP3 Player
Stays on gogear screen wont do nothing else
i try to turn on my philips it powers on for 1 sec then shuts right off
Dec 11, 2009 | Philips GOGEAR SA6045 MP3 Player
My gogear will only turn on for a second and only if the charger is hooked up
plug usb in and go to "my computer" right click on philips drive and select format click ok dont change any options.this does work i have same one and have done it.
May 31, 2009 | Philips GoGear SA5285/37 Digital Media...
Cant find my music on my device :'(
Yeah you need to format it then reset the device if that does not work try charging it.
Apr 17, 2009 | Philips GoGear SA5285/37 Digital Media...
My xbox360 is frezzing
Try cleaning the vents on the console with a vacuum cleaner with the xbox OFF
Then try playing without your hard drive
if it doesnt freeze without the hard drive youve got a problem
ring up xbox
Dec 16, 2008 | Microsoft Xbox 360 Console
Locked
Switch the lock symbol on the bottom of the player to unlock the little button from left to right. That should do the trick.
Apr 17, 2008 | Philips GOGEAR SA6045 MP3 Player
Will not play songs
There could be several things going on:
1)Your music service subscription could have been cancelled
2)The device itself is not faulty. This is Microsoft's fault, not Philips'. Some of the songs may have Digital Rights Management (DRM) encoding that the SA178 will not support. You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
Otherwise:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Aug 30, 2007 | Philips GoGear SA178 MP3 Player
Cant play files on my philips go gear 512mb windows media player
Otherwise:
-Tha Mp3 Doctor
Philips GoGear HDD6330 MP3 Player Logo
134 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
