Question about Roper RT21AKXKQ Top Freezer Refrigerator
My refrigerator is not getting cold. The freezer freezes good and water is dripping from the inside of the refrigerator onto the shelves what is causing that?
  • Roper Master
  • 4,655 Answers
That is condensate,. We need to see if your refrigerator is defrosting normally. Want you to find the defrost timer in photo below is a description and location. The #4 in photo is the defrost timer providing the model number above your post is correct. There should be a small round hole through the control panel to turn the defrost timer slowly clockwise until the compressor stop. When stopped this should put your refrigerator in defrost mode. Defrost should take about 25 minutes or little longer. If refrigerator does not restart turn the timer slowly again until the compressor restarts. If you need to restart this way the timer will need replaced. During defrost the freezer area will produce sounds of crackling and sizziling of water dripping down onto the defrost heater. If no sounds let me know the results and I will instruct you on what to do next. Sea breeze
Posted on Jun 24, 2009
  • John Tripp
    John Tripp Jun 24, 2009
    There also may be a defrost drain blockage but checking the defrost will be the first step. If defrost is working properly all condensate should go to the pan below your refrigerator and be heated by the condenser fan and placed back into the air inside your home. If that line is blocked all condensate remains inside refrigerator to later drain down to bottom sections and pool up and run out the door or freeze in bottom of freezer.
    Sergeant:
  • 187 Answers
pls chk this link
http://www.acmehowto.com/howto/appliance/refrigerator/diagrefrigerator.php
Pls rate my suggestion......
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
My refrigerator seems to be defrosting itself almost all of the time. Water is dripping onto the shelves. The fan or compressor is not on for quite a while, then after 20 minutes or so, they come back on....
There should be a regulator that controls the compresor, depending on model, depends where you will find it. Besides this control, there is an item called a relay that starts the compressor when needed. Check them both.
https://www.youtube.com/watch?v=5LvTdvyIFyg
Nov 30, 2017 | Kenmore 63742 Top Freezer Refrigerator
Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Sep 13, 2009 | Kenmore 71112 / 71114
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper RT21AKXKQ Top Freezer Refrigerator Logo
509 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
