Ford e-250 van max a/c barely blows...norm a/c blows fine. just started yesterday. heard a click then fan de-rated. when i switch to max i hear the fan speed up but seems contained within the dash as if blocked
  • 5,687 Answers
It is blocked. There is a blender door under the dash. It is operated by vacuum or a cable. The vacuum pot is called a vacuum motor. It could have a hole in it, have the rod skipped off, or the line feeding this part is not getting vacuum. It can be a problem with the control not switching vacuum to this part. Check with an autoparts place for a picture and replacement. If under warranty take it in. All you need to do is look under the dash, adjust controls and see if something does not move.
Posted on Jun 24, 2009
Blower fan not working
Could be the switch itself.
Jul 27, 2014 | 2005 Ford E-250 Van
1989 Ford Econoline 150 Van will not start
Most all vehicles have main power cable to starter solenoid which is mounted on the starter where the power cable to the switch connects OR there is a separate heavy gauge red wire connected to the positive post of the battery that leads to the ignition switch. Also check your ground cable by connecting battery jumper cable to negative post on battery and other end to metal frame of van.
May 22, 2017 | Ford Econoline Cars & Trucks
2003 dodge caravan will not start. Makes a clicking noise, and dash shuts off, then makes a humming sound.
im going to say an almost dead battery .the hum you hear might be the fuel pump.you never heard it before because the van normaly starts .so boost your van if it starts you may have to replace the altenator the guages, no worries many cars do that .thats a code needing erased and if you disconnect the battery that may go away.
Nov 22, 2013 | Dodge Caravan Cars & Trucks
85 E350 Ford not switching from Fnt to RR fuel tank
85 ford 350 econoline van with 460 engine and duel tanks, lost prime on both tanks, cannot get gas up to inlet on carb, it happen after having shot work on vaccum lines, i can't hear the pumps in the tanks making a buzzing noise, i hear a click when i switch from front tank to the rear tank , somewhere under the hood, on the driver side front fender, what is the next step.
Jun 26, 2009 | 1985 Ford Econoline
Air Conditioner Problems
Check for a vacuum leak. The vacuum cannister under the evap. case will crack and cause a leak. I just install a new vacuum cannister,check valve and hose going to inside of van.
May 28, 2009 | 2002 Ford E350
A/C blower issues
if the blower works sometimes check the blower motor resistor which should be located by the blower motor
Apr 28, 2009 | Chevrolet Monte Carlo Cars & Trucks
97 Ford Econoline air conditioning and vent settings blowing hot
I know from experience that if the coolant is to low ( not just the freon levels in the compresor but the antifreeze/coolant level as well) the AC system will not cool and will blow hot. Check the coolant Antifreeze and freon levels, even with the Coolant being a little low my 1998 Ford E150 Van will blow hot. After you have ruled out of these possibilities and the chance it is the thermostat most likely the problem is what Ford calls the "Flap" it controls the air flow through the vent system when you switch from Heat to AC. When the Flap is working it closes off one systems air flow so as to not interfere with the current climate selection.
Feb 21, 2009 | 1997 Ford Econoline
Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Dec 03, 2008 | 2000 Ford Escort
A/c problem
try the refrigerant level...if it had a lek and freon escapes...pressure switch will de activate compressor...
i hope i was ab;e to help...
tnx
drcool
pls rate me...
Jul 24, 2008 | 1999 Ford Windstar
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
