Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Big Blur when i turn the tv on
I have a 52" rca rear projection tv (model # D52W25) everytime i turn my tv on for the first 15 - 20 min the colors are all blurred and there are only red and blue colors after a about 20 min the colors come in not the best quality but good enough. Its also making a static sound... What can i do to fix this its horrible?
    Brigadier General:
  • 8,619 Answers
Hi!
First of all please check the following things:
Press the TV button. Make sure the TV is plugged in. Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else. Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions. The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Front Panel Block in the Parental Control menu and press OK to uncheck the box. The TV might be performing a periodic diagnostic check. Wait for a few minutes for the TV to turn on.
If still the problem persists then check the following:
Maybe the cable/air function is set to the wrong position. The channel might be blank — change channels. If you’re watching your VCR and it’s connected with coaxial cable to the CABLE/ANTENNA jack, tune the TV to channel 3 or 4 (whichever channel is selected on the 3/4 switch on the back of your VCR). Also check to make sure the TV/VCR button on the VCR is in the correct mode (press the TV/VCR button on your VCR). Check antenna connections. Make sure all of the cables are firmly connected to the jacks. Try adjusting sharpness function to improve weak signals. Closed-captioning might be on. Check Closed Caption in the Setup menu.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 24, 2009
Rca hd d52w25 tv was working fine turned it off when turned on now no picture or sound and power button flashes green
The most common cause of that symptom in that model are the CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with repair instructions.
Nov 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w25 52 inch blinks 3 times off...turns on...off
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at www.tvrepairworld.com under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Sep 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
High Squealing Sound
There is a stand up coil about 1" tall and the dia of a nickel close to the HV transformer, the iron core glue comes loose over usage. This can be cured by replacing it or using a sealer/caulk and re-seal the coil. Hope this helps, it is not an expensive job for service.
Feb 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca big screen model p52939
If you cannot get a good convergence then the convergence modules need replacing.
Jun 20, 2017 | RCA P52939 52" Rear Projection Television
RCA TV MODEL D52W25
Take the back off the TV look where the wire from the power plug enters the TV. There is a small fuse on the board where the wire plugs into. If that fuse is blown, you have a power supply problem.
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W25
Thats possibly the flyback causing that. If you need more help with the problem or how to change the flyback, let me know
May 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
Jan 25, 2008 | RCA P52960 52" Rear Projection Television
RCA Rear projection Tv D52W25
the would be you high voltage flyback do not run the set while this is happening as it could do more damage.
you should replace that part.
Jan 09, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
182 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
