Question about Maytag MSD2756G Side by Side Refrigerator
My side by side maytag refrig only cools to 60 degrees on the refrig side...... the circulation fan is working....however the coil had been frozen over with ice. I defrosted it but still the frig only cools to 60 degress. What is the likely componet to look for.
  • Maytag Master
  • 4,655 Answers
Your refrigerator has an Adaptive Deforst Control located in the control panel inside the fresh food section part number 61005988 is is the most likely reason for your trouble. Picture #13 below.
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 25, 2009
  • John Tripp
    John Tripp Jun 26, 2009
    My question is you defrosted the freezer and the fresh food section still only gets as low as 60 degrees? Or is everything working OK now?
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer is blowing and staying around 20 degrees and refrig is warm?
If you mean the rest of the refrigerator is warm, that means the fan that circulates the cool air from the cooling coils around the freezer compartment is broken, you'll need to send it in for repair.
Mar 06, 2011 | Refrigerators
Freezer is frozen, refrig is 60 degrees? Cause? Convection fan?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Microwave Ovens
Freezer works fine air is circulating and temp. is zero degrees refer side is 60 degrees and air does not seem to be circulating. Settings are set on 4 as they have been for five years Do I have to...
Check to see if your hear your evaporator fan is running in your freezer, then check behind the refrigerator and see if your condensor fan is running. Make sure your condensor coils are clean under your fridge. Your symptoms are leaning towards dirty condensor coils. Good luck!
Aug 19, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Hi..our maytag msd2351HE side by side is only making small amounts of ice..we are able to get water..Any suggestions?
I would suggest pulling the refrig out and removing the lower panel . On the right , there is a black box ( condensor ) . The fan pulls air thru the coils and dust , lint , etc , can block the air flow , causing the freezer to not get cold enough ( 5 degrees ) for the ice maker to work . Also check to make sure the fan there is working . If the fan is working and the coils are clean , try turning the freezer control slightly colder . If the fan is not working , replace the fan motor .
Aug 01, 2010 | Maytag MSD2351HE Side by Side Refrigerator
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Poorly Cooling Side Bu Side
the coils are actually behind the unit next to the fan assy(sorta a plate rolled over it self opposed to conventional coils on this particular unit).tyr removing hte lower panel in freezer section, check the evaporator.Should be an even frost pattern across hte entire coil, no frost with execption of the top 1 or 2 coils, is an indication of a sealed system issue( covered under 5 yr manufacture warr usually). excessive frost (cpmpartment completly frozen over) is a sign of bad defrost system.perhaps even the fan not circulating the cold air into the refrig compartmant
Mar 22, 2008 | Refrigerators
Maytag S/S model # MSD2756GEB
di you see or hear the fan running fan might be stuck check that out no fan no circulating cold air you may have problem with the heating element what make frost free inside you should melt all the ice inside around the damper check if you see broken glass the little heating element if it not broken and listen for that important fan if it running check it uot thank for using fixya pierre
Feb 05, 2008 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
264 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
