Question about Samsung LT-P1745 17 in. EDTV-Ready LCD Television
Surround sound dvd player/tv channels are fuzzy
I have a dvd surround sound player hooked up to my tv and when i switch from dvd to regular cable tv channels they are fuzzy?
Hi I have an RCA Truflat TV and a philips Surround sound dvd all in one system and a jvc dish system. I have had my surround working up until my nephews messed with it and hooked up a wii system to it. Now I get no sound on my surround sound and I have tried rearranging the cables but I can not get any sound from the surround sound and for the life of me I can not rember how I originaly had it set up. can you help?
Posted on Jul 12, 2009
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
Coby DVD968 surround sound w/TV
you have to check to see if your TV also has "AUDIO OUTPUT" ports, they would be red/white (not next to a yellow - those are inputs", you would hook up red/white from back of the TV to the back of the DVD player where it is labeled "input", you then turn on the dvd player and press the 'source' button to switch it to the right input for your connection. P.S. - it will only do the front two speakers because your tv only outputs 2 channel audio.
May 19, 2013 | Coby DVD968 Theater System
I was hooking up my sisters surround reciever for her and used an optical cable to the reciever from the TV. Her TV gets signal from the cable box via coax and uses HDMI from DVD player. I am stumped that...
srry but the tv is not capable of sending hdmi audio through its outputs the dvd player audio must be run through rca red and white or black if you have digital audio out to the back of the receiver on its own channel
Jan 11, 2011 | Audio Players & Recorders
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
Jan 27, 2010 | RCA RT2400R Receiver
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Jun 14, 2009 | Philips 32PF7421D 32 in. LCD HDTV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Hooking up a PS3 to my surround sound
you have to go to the set up menu and let the receiver know that you are inputting dvd audio to the digital in. (assigning). that way, when you switch the receiver to dvd, it will look for audio from the digital input. your receiver manual will guide you through that set-up.
if that does not work, the fiber optic cable could be bad. this is more common than people would expect.
another option is to just rca cables to the receiver from the ps3. there is an adapter that lets you do that.
good luck
mark
Dec 28, 2007 | Televison & Video
Samsung LT-P1745 17 in. EDTV-Ready LCD Television Logo
295 people viewed this question
Jerry Greenberg
Jerry Greenberg
